Author Topic: Modify DWGUNITS  (Read 1431 times)
FELIX
Modify DWGUNITS
« on: April 25, 2024, 05:40:35 PM »
How to modify the value in -DWGUNITS from 3 to 6 by AutoLISP?
Command: -DWGUNITS
Drawing units:
  1. Inches
  2. Feet
  3. Millimeters
  4. Centimeters
  5. Decimeters
  6. Meters
Unit for length <3>: 6
OK.
BIGAL
  • 40 + years of using Autocad
Re: Modify DWGUNITS
« Reply #1 on: April 25, 2024, 08:16:33 PM »
Something like this
(command "-dwgunits" 6 2 3 "N" "Y")
ScottMC
Re: Modify DWGUNITS
« Reply #2 on: April 26, 2024, 09:55:58 AM »
With my ancient A2K, this works: (setvar "LUNITS" 2) <- for decimal
Lonnie
Re: Modify DWGUNITS
« Reply #3 on: April 26, 2024, 11:45:03 AM »
Untested but?
(defun check-and-set-lunits ()
  (if (/= (getvar "LUNITS") 6) ; Check if LUNITS is not already set to 6
        (setq change_units (strcat "\nLUNITS is currently set to " (itoa (getvar "LUNITS")) ", do you want to change it to 6? [Y/N]: "))
        (if (equal (getstring change_units) "Y")
            (setvar "LUNITS" 6) ; Change LUNITS to 6
            (prompt "\nLUNITS remains unchanged.")))))
(check-and-set-lunits)
Change for meters
« Last Edit: April 26, 2024, 11:56:06 AM by Lonnie »
huiz
  • Certified Prof C3D
Re: Modify DWGUNITS
« Reply #4 on: April 26, 2024, 03:52:42 PM »
DWGUNITS can have another setting, it is optional to match AutoCAD units settings.
PKENEWELL
Re: Modify DWGUNITS
« Reply #5 on: April 26, 2024, 04:37:07 PM »
I would rather note that LUNITS is a sub-setting within the UNITS command, along with ANGDIR, AUNITS, ANGBASE, INSUNITS, LUPREC and AUPREC. Other system Variables that effect units are MEASUREINIT, MEASUREMENT and UNITMODE.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
huiz
Re: Modify DWGUNITS
« Reply #6 on: April 27, 2024, 03:39:39 AM »
I did't say it isn't. DWGUNITS is something different. From origin it comes from a vertical, AutoCAD Architecture I think. Within DWGUNITS you can set some unit settings and it is optional to match them with the AutoCAD units.
Normally you don't notice the DWGUNITS stuff but there are cases you do.
The best setting is to match AutoCAD units and then forget all about DWGUNITS.
FELIX
Re: Modify DWGUNITS
« Reply #7 on: May 17, 2024, 11:44:21 PM »
Untested but?
Change for meters
The command is -DWGUNITS and LUNITS does not accept =6
OK.
FELIX
Re: Modify DWGUNITS
« Reply #8 on: May 17, 2024, 11:46:23 PM »
Something like this
How to do it without COMMAND to look elegant within a program?
OK.
JasonB
  • perfectionist trapped inside the mind of an idiot.
Re: Modify DWGUNITS
« Reply #9 on: May 18, 2024, 04:58:21 PM »
Command: -DWGUNITS
Drawing units:
  1. Inches
  2. Feet
  3. Millimeters
  4. Centimeters
  5. Decimeters
  6. Meters
This part of the command relates to INSUNITS
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-A58A87BB-482B-4042-A00A-EEF55A2B4FD8
  1. (setvar 'INSUNITS 6)
PKENEWELL has listed this and the other system variables related to this command.
FELIX
Re: Modify DWGUNITS
« Reply #10 on: May 18, 2024, 09:13:17 PM »
The command is -DWGUNITS and not INSUNITS or LUNITS.
Please pay more attention before responding.
OK.
JasonB
Re: Modify DWGUNITS
« Reply #11 on: May 19, 2024, 01:54:55 AM »
-DWGUNITS is a command.
INSUNITS and LUNITS are system variables
As others have pointed out, -DWGUNITS looks to be related to an AutoCAD Vertical. It's not documented anywhere that I could find in the HELP. Also, from other posts it seems geared more towards converting a drawing from one set of units to another. Further to this, the prompting of the command changes depending on whether you've run the command previously in a drawing. So simply calling
  1. (command "._-DWGUNITS" 6 2 3 "_N" "_Y")
may not work in all cases.
If you're simply trying to set the drawing units, then it would be better to explore the -UNITS command.
All the settings of the -UNITS command can be set via a system variable, which allows you to avoid making a command call from lisp. This is a more elegant approach. e.g
  2. (setvar 'LUNITS 2)
  3. (setvar 'LUPREC 4)
