Author Topic: Issue selecting certain multileader objects  (Read 789 times)
slissner
  • Mosquito
« on: March 25, 2024, 09:31:49 PM »
I am working on an AutoLISP command which involves rotating Multlleader objects (attached). I am having an issue where certain Multileader objects are crashing with the error:
Exception has occurred. AutoCAD.Application: Invalid index
Some objects crash my routine and others don’t, I have been unable to figure out why. I have attached the AutoLISP script. I am crashing on line 58 when I try and retrieve an attribute from the Multileader with the line:
(vlax-invoke ml_obj "GetDoglegDirection" 0)
I’d appreciate any pointers or documentation to help get me moving in the right direction, for now I am quite stumped.
VovKa
  • Ukraine
Re: Issue selecting certain multileader objects
« Reply #1 on: March 26, 2024, 08:20:55 AM »
post a dwg with such an object
slissner
  • Mosquito
« Reply #2 on: March 26, 2024, 01:01:38 PM »
Here you go. The red, 15 degree multileader crashes the command.
« Reply #3 on: March 26, 2024, 01:52:56 PM »
This could be part of the problem.
Auditing AcDsRecords
Total errors found 68 fixed 68
Erased 68 objects
See if the attached file works.
slissner
  • Mosquito
« Reply #4 on: March 26, 2024, 04:00:39 PM »
No luck unfortunately. I've tried auditing other files that engineers have brought me and had no success with those either. Maybe it has something to do with the way that the objects are created? I'm at a loss.
VovKa
  • Ukraine
« Reply #5 on: March 27, 2024, 09:30:43 AM »
(setq dogLegDir (vlax-invoke ml_obj "GetDoglegDirection" (vlax-invoke ml_obj "GetLeaderIndex" 0)))
slissner
  • Mosquito
« Reply #6 on: March 27, 2024, 12:48:23 PM »
This fix seems to be working! Thank you VovKa!
dexus
« Reply #7 on: March 27, 2024, 01:25:26 PM »
You can also have a look at this: https://www.theswamp.org/index.php?topic=55023.msg614986#msg614986
It is able to retreive multiple arrows on a single mleader.
VovKa
  • Ukraine
« Reply #8 on: March 27, 2024, 01:53:01 PM »
welcome to theswamp, slissner
« Reply #9 on: April 05, 2024, 06:31:36 AM »
I think this might be cleaner -
  1. (defun doglegdirection ( ent / enx )
  2.     (if (and (setq enx (entget ent))
  3.              (= "MULTILEADER" (cdr (assoc 0 enx)))
  4.              (setq enx (member '(302 . "LEADER{") enx))
  5.         )
  6.         (cdr (assoc 11 enx))
  7.     )
  8. )
  1. (defun c:test ( / ent )
  2.     (if (setq ent (car (entsel)))
  3.         (print (doglegdirection ent))
  4.     )
  5.     (princ)
  6. )
dexus
« Reply #10 on: April 05, 2024, 08:57:45 AM »
As always making it look simple, well done.
I modified it so you can check for multiple leaders, in case the mleader has an arrow on both sides:
  1. (defun doglegdirection ( ent / enx rtn )
  2.   (if
  3.     (and
  4.       (setq enx (entget ent))
  5.       (= "MULTILEADER" (cdr (assoc 0 enx)))
  6.       (while (setq enx (member '(302 . "LEADER{") enx))
  7.         (setq rtn (cons (cdr (assoc 11 enx)) rtn)
  8.               enx (cdr enx))
  9.       )
  10.     )
  11.     (reverse rtn)
  12.   )
  13. )
