Author Topic: (challenge)? ASSOCiate by value vs. key  (Read 4557 times)
daron
« on: July 12, 2005, 01:32:28 PM »
Take this list:
(setq stdWallList '((0 . "Basement") (1 . "Garage") (2 . "Stoop")
    (3 . "Arm") (4 . "Haunch")
and find the associated value of "Stoop".
What I'm looking for is the reverse of:
(cdr (assoc 2 stdWallList)
« Reply #1 on: July 12, 2005, 02:00:21 PM »
(cadr (assoc "Stoop" (mapcar '(lambda (x) (list (cdr x)(car x))) stdWallList)))
edit - changed to cadr
daron
« Reply #2 on: July 12, 2005, 02:04:52 PM »
That's good CAB. I came up with:
(defun revassoc (itempred itemcomp / newitemlist)
     (foreach item itempred
 (if (= itemcomp (cdr item))
      (setq newitemlist (append newitemlist (list item)))
     newitemlist
Not too challenging. I'd like to see the varied possibilities.
whdjr
« Reply #3 on: July 12, 2005, 02:18:47 PM »
(defun test (str lst)
  (caar (vl-remove-if-not '(lambda (x) (eq (cdr x) str)) lst))
« Reply #4 on: July 12, 2005, 02:20:09 PM »
Thanks,
I changed mine to cadr ILO cdr
daron
« Reply #5 on: July 12, 2005, 02:23:20 PM »
With a small edit, the one I made above can be made to reflect exactly the way assoc does when it encounters multiple key values:
;example: (revassoc stdwalllist "Garage")
     (car newitemlist)
My previous one returns a list of all key's equal. This one returns the first of all in just a list, instead of a nested list.
« Reply #6 on: July 12, 2005, 02:37:39 PM »
Here is another.
(defun revassoc (itm lst)
  (vl-some '(lambda (x) (if (= (cdr x) itm)(car x))) lst)
Did you want the lisy back like this?
  (vl-some '(lambda (x) (if (= (cdr x) itm) x)) lst)
« Reply #7 on: July 12, 2005, 02:53:28 PM »
Quote from: CAB
I would keep the use of (cdr) since you are supposed to be using an association list. Which means you need to build the association list in reverse....just a slight mod. to CAB's code:
(cdr (assoc "Stoop" (mapcar '(lambda (x) (cons (cdr x)(car x))) stdWallList)))  :D
« Reply #8 on: July 12, 2005, 03:05:49 PM »
Quote from: Coolhand Luke
What we have here is a failure to communicate.
:shock:
Quote from: daron
(cdr (assoc 2 stdWallList))
That doesn't return a list. :D  :D
« Reply #9 on: July 12, 2005, 03:07:53 PM »
Quote from: CAB
Nor does the code I modified with (cons) in place of (list)  8)  :P
« Reply #10 on: July 12, 2005, 03:22:11 PM »
Oh, I see what you did. :oops:  The internal result is a dotted pair.
That way it has the same look as the usual code.
How about this:
(defun rv_list (lst)
  (mapcar '(lambda (x) (cons (cdr x)(car x))) lst)
(cdr (assoc "Stoop" (rv_list stdWallList)))
« Reply #11 on: July 12, 2005, 03:26:55 PM »
Exactly! I have one of these for switching around layer names for a client with a strange layer naming "standard". The layers are in an assoc list ("MyLayer" . "HisLayer"), etc., then when I want to flip to my layers I just call it (fliplay laylist nil) or to his (fliplay laylist t)....depending the arg. being true I just flip 'em around.
daron
« Reply #12 on: July 12, 2005, 04:08:22 PM »
Sorry if there was any miscom. I was trying to leave it a little open. It's good for variations that don't get too far away from the point. It could spur ideas that weren't there to begin with. I should've left out the cdr assoc bit.
SMadsen
« Reply #13 on: July 12, 2005, 04:38:51 PM »
(defun rvAssoc (item lst)
  (cond ((null lst) nil)
        ((eq (cdar lst) item) (car lst))
        ((rvAssoc item (cdr lst)))
daron
« Reply #14 on: July 13, 2005, 12:50:20 PM »
Sweet recursion. I had hoped for something like that too. Thanks Stig.
