Author Topic: List Manipulation Help  (Read 954 times)
abe123456789
« on: April 06, 2023, 09:17:18 PM »
Hello,
How can I achieve the desired list using lisp?
starting list
lst = 1 2 3 4 5 6 7
Desired list
lst = (1 2) (2 3) (3 4) (4 5) (5 6) (6 7)
Thank you,
« Last Edit: April 06, 2023, 09:24:23 PM by abe123456789 »
BIGAL
  • 40 + years of using Autocad
Re: List Manipulation Help
« Reply #1 on: April 06, 2023, 11:03:18 PM »
Something like this I will let you have a go.
x 0
repeat (- (length lst) 1)
(cons (nth x lst)(nth (+ x 1) lst))
(1+ x)
Tharwat
  • Hypersensitive
« Reply #2 on: April 07, 2023, 04:43:14 AM »
  1. (setq lst '(1 2 3 4 5 6 7))
  2.
  3. (and (< 1 (length lst))
  4.      (setq 1st (car lst))
  5.      (while (setq lst (cdr lst))
  6.        (setq rtn (cons (list 1st (setq 1st (car lst))) rtn))
  7.        )
  8.      )
  9. (reverse rtn)
  10.
gile
  • Marseille, France
« Reply #3 on: April 07, 2023, 04:48:45 AM »
  2. (mapcar 'list lst (cdr lst)))
abe123456789
« Reply #4 on: April 07, 2023, 09:37:18 AM »
Thanks for the help guys. :-)
Jim2018
  • Mosquito
« Reply #5 on: April 09, 2023, 05:12:58 AM »
Sorry gile
but I don't understand the function of the command (mapcar 'list lst (cdr lst))).
Normally the result should be different as follows ((1 2 3 4 5 6 7) (2 3 4 5 6 7) (3 4 5 6 7) (4 5 6 7) (5 6 7) (6 7))
and yet it is not!
Why when we put (cdr lst) does not result in all the elements except the first one?
Also why (marcar 'list (cdr lst)) has as a result ((2) (3) (4) (5) (6) (7)) and not  ((2 3 4 5 6 7) (3 4 5 6 7) (4 5 6 7) (5 6 7)(6 7))?
gile
  • Marseille, France
« Reply #6 on: April 09, 2023, 05:55:48 AM »
From the docs: the mapcar function "Returns a list that is the result of executing a function with a list (or lists) supplied as arguments to the function"
So, assuming lst is equal to '(1 2 3 4 5 6 7), (mapcar 'list lst)  returns: ((1) (2) (3) (4) (5) (6) (7)) because it returns a list that is the result of executing the list function to all items in lst.
Which is equivalent to: (list (list 1) (list 2) (list 3) (list 4) (list 5) (list 6) (list 7))
Same thing for: (mapcar 'list (cdr lst)) which is equivalent to (list (list 2) (list 3) (list 4) (list 5) (list 6) (list 7)) and return ((2) (3) (4) (5) (6) (7))
When mapcar is called with more than one list, the supplied function (list function here) is applied to all corresponding items of the lists while none of the list is empty.
(mapcar 'list lst (cdr lst)) is equivalent to: (list (list 1 2) (list 2 3) (list 3 4) (list 4 5) (list 5 6) (list 6 7)) which returns ((1 2) (2 3) (3 4) (4 5) (5 6) (6 7)).
Jim2018
  • Mosquito
« Reply #7 on: April 09, 2023, 09:39:06 AM »
Hi gile
I know the way the mapcar command works
I don't understand why (cdr lst) would have this effect.
How does it happen when the mapcar calculates for the first element (cdr lst) returns the value of the second element and so on. I can't understand that.
The cdr command when applied to a list generally returns the list minus the first element.
Thank you very much for your time
gile
  • Marseille, France
« Reply #8 on: April 09, 2023, 10:14:00 AM »
stands for:
(mapcar 'list '(1 2 3 4 5 6 7) '(2 3 4 5 6 7))
which is similar to:
and returns:
Jim2018
  • Mosquito
« Reply #9 on: April 09, 2023, 10:55:46 AM »
Thank you gile
I realized my mistake. I calculated the (cdr lst) over and over for each element of the list.
The mapcar iterates through the lst and its (cdr lst), so simple!
