Author Topic: Batch Find & Replace Text AutoCAD 2023  (Read 7526 times)
Evangelos
  • Mosquito
« on: March 14, 2023, 06:02:12 AM »
Hello Everybody !
I am looking for LISP to Batch Find & Replace Text/Attributes/Mtext, BFind from Lee not working on AutoCAD 2023. Any idea ? Thanks a lot !
Evangelos
  • Mosquito
Re: Batch Find & Replace Text AutoCAD 2023
« Reply #2 on: March 14, 2023, 10:43:18 AM »
« Reply #3 on: March 14, 2023, 10:51:23 AM »
Load the lisp file with APPLOAD.
Type (on the command line): (txtfind "OLDtext" "NEWtext")
Evangelos
  • Mosquito
« Reply #4 on: March 14, 2023, 11:03:54 AM »
Not working too (AutoCAD 2023)
« Reply #5 on: March 14, 2023, 11:06:20 AM »
Would you be a little more specific. That code would work in R14 as well as it would in AutoCAD for Mac. How is it (or other functions) not working?
Evangelos
  • Mosquito
« Reply #6 on: March 14, 2023, 11:09:32 AM »
...the routine did not replace any text ! I try in a new empty DWG and working just fine !
3dwannab
« Reply #7 on: July 07, 2023, 06:11:47 PM »
I had this problem. I opened the file in my IDE, VS code and it formatted it.
Try downloading the file again from his site.
pablo123
  • Mosquito
« Reply #8 on: May 09, 2024, 12:35:47 PM »
I have the same problem as @Evangelos. When I had AutoCad 2017 versions the lisp worked great. After updating AutoCad to 2023 the lisp does not work properly. It is only possible to replace single letters and characters for example: 2 can replace to 55, J can replace to Jacob. It is not possible to replace a longer string of characters than 1. Has anyone managed to solve this problem ? Maybe AutoDesk uses additional security to use paid versions.
« Reply #9 on: May 10, 2024, 12:46:23 PM »
Try setting LISPSYS to 0.
