Author Topic: Point offset in Polyline  (Read 2085 times)
FELIX
« on: February 22, 2023, 03:15:50 PM »
From a selected polyline and an informed distance X I select a point P1.
I want to have a point P1A and P1B as an offset.
OK.
Re: Point offset in Polyline
« Reply #1 on: February 22, 2023, 07:08:31 PM »
The easiest approach is to make use of the various vlax-curve-* functions, specifically: vlax-curve-getclosestpointto (to obtain a point on the polyline, given a point obtained from the user), vlax-curve-getparamatpoint (to determine the parameter of the point returned), & vlax-curve-getfirstderiv (to obtain the tangent vector at the given point).
From the tangent vector, you can calculate a perpendicular vector which may be scaled by the distance 'X', or alternatively, you can calculate the angle of the tangent vector, add/subtract pi/2 radians, and calculate the offset points using the polar function.
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: February 22, 2023, 07:25:09 PM »
Like Lee, for distance along a pline use  (vlax-curve-getpointatdist obj len)
xdcad
« Reply #3 on: November 22, 2023, 05:03:48 PM »
Use code to translate the master’s words:
  1. ;|
  2. Suitable for calculating point offset on any curve
  3. single point
  4. |;
  5. (defun XD::Curve:OFSPnt (e pnt offsetx / pnt xdir ydir mat)
  6.   (setq pnt  (xdrx-getpropertyvalue e "getClosestPointTo" pnt)
  7.                                         ; closest point
  8.         xdir (xdrx-getpropertyvalue e "firstderiv" pnt)
  9.                                         ; tangent vector
  10.         ydir (xdrx-vector-perpvector xdir) ;vertical vector
  11.         mat  (xdrx-matrix-settranslation
  12.                (xdrx-vector-product ydir offsetx)
  13.                                         ; translation transformation matrix
  14.              )
  15.   )
  16.   (list (xdrx-point-transform pnt mat)  ; The transformation matrix is applied to the point
  17.         (xdrx-point-transform pnt (xdrx-matrix-inverse mat))
  18.   )
  19. )
  20. ;Multiple points, point table to find offset points
  21. (defun XD::Curve:OFSPnts (e pnts offsetx / pnt xdir ydir mat)
  22.   (mapcar '(lambda(x)(xd::curve:ofspnt e x offsetx)) pnts)
  23. )
« Last Edit: November 22, 2023, 11:20:39 PM by xdcad »
The code I wrote uses XDRX-API,which can be downloaded from github.com and is updated at any time.
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: November 22, 2023, 05:13:00 PM »
@xdcad,
should the pnts parameter passed in be pnt ??
because of the
For Interest,
Why do you think the xdrx-xx method is better than the ActiveX method
  1. (vlax-curve-getClosestPointTo curve-obj givenPnt [extend])
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-90F585FE-D5C8-4C08-AFC7-A09A697EA52A
or using
  1. (vlax-get-property object property)
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-B3F22E35-4666-452F-89C8-5BC15B9E9463
« Last Edit: November 22, 2023, 07:11:55 PM by kdub_nz »
Called Kerry in my other life
I live at UTC + 13.00
xdcad
« Reply #5 on: November 22, 2023, 11:31:46 PM »
@xdcad,
because of the
For Interest,
or using
It doesn’t matter which method is better, XDRX or ActiveX
As long as it can catch mice, it's a good cat
XDRX API communicates directly with ARX, ActiveX needs to "go around a little further"
XDRX API is developed in applications, mainly to solve problems and be more "humane"
The LISP code written by XDRX is closer to the thinking of C++ ARX.
Including the processing methods of matrices, vectors, etc., regardless of efficiency, ARX is better in terms of legibility.
Because it is closer to a mathematical solution
In LISP, brackets within brackets make it difficult to see the logic clearly in many codes.
All roads lead to Rome
As for whether XDRX is good or bad, using it more may pay more attention to understanding.
XDRX API is the programming package of C++ ARX. In many cases, it is how to write C++ (ARX), and XDRX API is directly translated into LISP.
