Author Topic: CUILOAD what CUIX files to load  (Read 1844 times)
sigster
« on: May 30, 2021, 09:29:58 PM »
Hi
I am working on WIX setup
when I use CUILOAD and change CUIX file AutoCAD load
where do AutoCAD keep the information what CUIX  files to load
Regards
Sigster
Crank
Re: CUILOAD what CUIX files to load
« Reply #1 on: June 22, 2021, 04:40:21 PM »
The sub cuix-files that will be side loaded are stored in the main.cuix
The main cuix-file that will be loaded depends of the profile (*.arg) you use.
The profile that will be used can be defined in the shortcut that you use to start AutoCAD.
Lonnie
« Reply #2 on: June 22, 2021, 05:43:05 PM »
If you really want to play. You can rename the CUIX to zip and look around. You can also pull out your cui files run it them through the menuload or cui commands to create a mnr file you can edit.
Just sayin. I've heard you should not do it but it's not screwed up on me yet so don't cuss me if you edit your only file and it no longer works. ok?
sigster
« Reply #3 on: July 02, 2021, 08:35:58 AM »
