Author Topic: Remove a toolbar  (Read 1930 times)
GDF
Remove a toolbar
« on: February 22, 2020, 02:19:37 PM »
How would I remove a toolbar without using a command:
(command "toolbar" "ARCH.Arch2Program©" "hide")
I want it to work thru a reactor...
  1. (defun C:RARCH ()
  2.   (princ "\n*** ---- Resetting ARCH Menu Pulldown ---- ***")
  3.   (cond
  4.     ((or (= (nth 0 (ARCH:Split (getvar "dwgprefix") "\\")) "Z:")(= (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 5)) "Drawing"))
  5.       (ARCH:NotInDirectory))
  6.     ((or (/= (nth 0 (ARCH:Split (getvar "dwgprefix") "\\")) "Z:")(/= (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 5)) "Drawing"))
  7.       (ARCH:InDirectory)))
  8.   [b];;(command "toolbar" "ARCH.Arch2Program©" "hide")[/b]
  9.   (princ))
  10. ;;;
  11. (defun rarchit (calling-reactor commandinfo) (C:RARCH) (princ))
  12. (vlr-docmanager-reactor () '((:vlr-documentBecameCurrent . rarchit)))
EDIT (John): Added code tags.
« Last Edit: February 22, 2020, 03:01:19 PM by John Kaul (Se7en) »
GDF
Re: Remove a toolbar
« Reply #1 on: February 22, 2020, 02:57:16 PM »
  1. (defun ax:Toggle (mGroup tBarName / tbar)
  2.   (if (= (vla-get-visible tbar) :vlax-true)
  3.     (vla-put-visible tbar :vlax-false)
  4.     (vla-put-visible tbar :vlax-true)
  5.   )
  6.   (princ))
  7.
  8.
  9. (ax:Toggle "ARCH" "Arch2Program©")
« Last Edit: February 22, 2020, 03:01:36 PM by John Kaul (Se7en) »
GDF
« Reply #2 on: February 22, 2020, 03:22:03 PM »
I got this to work:
(defun ax:Toggle-off (mGroup tBarName / tbar)
  (setq tbar (vla-item (vla-get-toolbars (vla-item (vla-get-menugroups (vlax-get-acad-object)) mGroup)) tBarName))
  (if (= (vla-get-visible tbar) :vlax-true) (vla-put-visible tbar :vlax-false))
  (princ))
(defun ax:Toggle-on (mGroup tBarName / tbar)
  (if (= (vla-get-visible tbar) :vlax-false) (vla-put-visible tbar :vlax-true))
  (princ))
(defun C:RARCH ()
  (ARCH:GDFstandard)
      (progn (ax:Toggle-off "ARCH" "Arch2Program©")(ARCH:NotInDirectory)))
      (progn (ax:Toggle-on "ARCH" "Arch2Program©")(ARCH:InDirectory))))
  (princ))
GDF
« Reply #3 on: February 22, 2020, 03:25:30 PM »
Well it works in BricsCAD but not AutoCAD.
GDF
« Reply #4 on: February 22, 2020, 09:37:59 PM »
I found the error, a toolbar command call; which AutoCAD does not allow within a reactor.
