Has anyone else found that the minimum system required for Civil 3D by Autodesk seem to be inadequate to the task for any real work? We have grown weary of watching the program grind away for minutes at a time on our work stations that should be more than up to the task per the documentation. Users were frequently assuming it hopelessly locked and would exit via Task Manager. We are now assembling a new prototype machine to find the most economical component upgrades that will actually run this thing and I was hoping others were having similar problems and might be willing to share some of their problems and findings.
These are the workstations that proved to be inadequate:
AMD XP2500, 512mb, Matrox 16mb AGP video & 60 - 120mb ide HD
We started the new prototype with this:
AMD 64, 1gb, ATI 128mb Raydon AGP Video with the old hard drives.
This provided some performance boost on startup, but still left the program hanging for extended periods before clearing the command.
We have since gone to an AMD 3700 Venus processor with 2gb of memory and N'Videa Quadro 128mb PCI+ video. The most recent addition of a 72gb SATA WD 10,000 rpm Raptor hard drive has been the most efficent upgrade to date. At this point, I would suggest this addition first if your system can exploit it while the video card upgrades seemed to have little impact.
One thing we noticed along the way here is that the fresh install of both OS (XP Pro SP2) and design software had nearly as much performance impact in our early tests as the new hardware we added. 64 bit Windows works well with this, but adequate drivers for both mouse and plotter are not yet ready at last report.
