Author Topic: Need assistance with expand ing a routines capabilities  (Read 5548 times)
pochrist
« on: June 09, 2005, 11:46:42 AM »
This Routine (Match Text) Allows me to match text strings like Match Properties does with colors. It works with/on Dtext, Mtext and Attributes.
It however does not work with the New Tables that Autocad has introduced in 2005. While updating some drawings I decided to convert our Schedules to Tables, but this routine doesn't work on Tables. I would like to Modify / update this routine to Include the editing of Tables into its capabilities. After studying the code I can't however determine where or how it can distinguish from Mtext, Dtext or Attibuted text. I thought I'd atleast find a Variable calling out (If you select an Mtext entity do Such and Such). Anyway if some could point me in the right direction I'd appreciate it.
(defun C:Matchtxt (/ ent enttxt ent2)
  (while (not ent)
    (setq ent (ENTGET (CAR (NENTSEL "\nSelect needed text!"))))
  (setq enttxt (cdr (assoc 1 ent)))
  (setq ent2 T)
  (while ent2
      ((setq ent2 (CAR (NENTSEL "\nSelect text to be changed!")))
       (SETQ SAVENAME ENT2)
       (SETQ ENT2 (ENTGET ENT2))
       (setq ent2 (subst (cons 1 enttxt) (assoc 1 ent2) ent2))
       (entmod ent2)
       (ENTUPD SAVENAME)
      ((= (getvar "errno") 7)
       (princ " Missed Selection. ")
       (setq ent2 T)
      (T (setq ent2 nil))
(Edit: MP fixed code formatting per this post).
whdjr
« Reply #1 on: June 09, 2005, 11:48:30 AM »
If you change the data the table is referencing can't you just update the table to reflect the change?
pochrist
« Reply #2 on: June 09, 2005, 12:05:24 PM »
Table isn't "Referanceing" or linked to another file. It is a Indvidual enity filled with strings of Mext. We don't use Schedules that constantly get changed this schedule is Simply just Text in Boxes I re did it to make it easier to format.
whdjr
« Reply #3 on: June 09, 2005, 12:12:03 PM »
oh, ok.
« Reply #4 on: June 09, 2005, 02:05:07 PM »
This will return the text string.
(if (setq ent (car (nentsel "\nSelect Table: ")))
     (setq obj (vlax-ename->vla-object ent))
     (princ (vla-get-Textstring obj))
pochrist
« Reply #5 on: June 09, 2005, 02:28:56 PM »
Thanks Mark, I added the code to the Routine, and I can get to work in one direction ( I can pick the Text in the Table and "transfer" it another Text Entity, But I can't do the reverse (ie Mtext or Dtext to the Table).
Did I put it in the wrong spot or did I forget something. TIA
  (while (not ent)
  (setq ent2 T)
  (while ent2
       (entmod ent2)
       (ENTUPD SAVENAME)
       (setq ent2 T)
      (T (setq ent2 nil))
« Reply #6 on: June 09, 2005, 03:02:41 PM »
      (vla-put-TextString obj "<string>")
      (vla-update obj)
Try that.
pochrist
« Reply #7 on: June 09, 2005, 04:39:26 PM »
Well I hate to report that the new code didn't change anything, which is kinda good cause It still does more then it did before. I'd assume that all these functions use the Clipboard to tranfer/duplicate the text. I know that the table supports Clipbord function between fields, which is why I'd like to use this Routine on them, it be much faster to click twice then do all the extra Crtl-C, Ctrl-V. TIA
« Reply #8 on: June 09, 2005, 05:26:54 PM »
Try a regen after you change the text.
Nope. You can however with DOSLib.
pochrist
« Reply #9 on: June 10, 2005, 09:14:53 AM »
Ok this is what the Routine looks like:
  (while (not ent)
  (setq ent2 T)
  (while ent2
       (entmod ent2)
       (ENTUPD SAVENAME)
      (vla-update obj)
       (setq ent2 T)
      (T (setq ent2 nil))
I tried regenerating after wards and here's what I get:
If I try to "Match text" from an Mtext Entity - After the regen the Value in the Field I pick changes to <string>
If I try to "Match text" from Field to Field - After the regen I get No change.
Maybe I formated it wrong? TIA
pochrist
So is this no longer do able?
« Reply #10 on: June 14, 2005, 10:40:50 AM »
It seems to have slipped in the It has been fixed or the It Can't be Done catagory. :?:
« Reply #11 on: June 14, 2005, 01:06:20 PM »
I was hoping you'd fixed it. :)
try something like this; still need a regen after change text in a table.
(defun c:MatchText (/ GetText PutText copy_txt)
  (defun GetText (/ ent)
    (if (setq ent (car (nentsel "\nSelect text needed: ")))
      (cdr (assoc 1 (entget ent)))
  (defun PutText (cp_txt / ent entlst)
    (if (setq ent (car (nentsel "\nSelect text tp be changed: ")))
(setq entlst (entget ent))
(setq entlst (subst (cons 1 cp_txt) (assoc 1 entlst) entlst))
(entmod entlst)
  (if (setq copy_txt (GetText))
    (PutText copy_txt)
Crank
« Reply #12 on: June 14, 2005, 02:14:29 PM »
Try this:
; ReplaceText.lsp by J.J.Damstra
; 10-01-02 first release
; 15-04-05 UNDO GROUPING
(defun c:RT (/ TXT_STR ENTITY ENTITY_NAME ENTITY_LIST OLD_VALUE NEW_VALUE NEW_ENTITY_LIST BLOCKOBJ)
(command ".undo" "begin")
(setq ENTITY (nentsel "\nSelect source text: ")
    ENTITY_NAME (car ENTITY)
    ENTITY_LIST (entget ENTITY_NAME))
(if (and (= (cdr (assoc 0 ENTITY_LIST)) "MTEXT")(/= (cdr (assoc 3 ENTITY_LIST)) nil))
(progn (alert "Error: This string is to long.") (exit)); max. 250
(setq TXT_STR (cdr (assoc 1 ENTITY_LIST)))
(while (setq ENTITY (nentsel "\nSelect text to change: ")) ; NIL > WEND
(if (> (length ENTITY) 3)(setq BLOCKOBJ (car (last ENTITY)))(setq BLOCKOBJ nil))
(setq ENTITY_NAME (car ENTITY)
    OLD_VALUE (assoc 1 ENTITY_LIST)
    NEW_VALUE (cons  1 TXT_STR))
(alert "Strange but true: This string is to long!\n(max. length = 250)")
(setq NEW_ENTITY_LIST (subst NEW_VALUE OLD_VALUE ENTITY_LIST))
(entmod NEW_ENTITY_LIST)
(if (setq ENTITY (cdr (assoc -1 ENTITY_LIST))) (entupd ENTITY))
(if BLOCKOBJ (entupd BLOCKOBJ))
(command ".undo" "end")
pochrist
Your Gonna Love this....
« Reply #13 on: June 15, 2005, 09:34:52 AM »
Tried Both the Modified code by Mark and the Routine by Crank.
The code you had prior to this June 10th version did was half way there
Dtext to Dtext, Attribute or Mtext = Fine
Attribute to Dtext, Attribute or Mtext = Fine
Mtext to Dtext, Attribute or Mtext = Fine
Table to Dtext, Attribute or Mtext = No Go
(Worked in the june 10th version TO Dtext, Attribute or Mtext but not from Table to Dtext, Attribute or Mtext.
When I try to take text from say an Mtext object I get "Missed Pick" and No change after regen either.
Crank same problem
Same problem minus the "Missed Pick" message
Crank
« Reply #14 on: June 15, 2005, 02:43:53 PM »
Are you sure? It works for me.
The only tables I have problems with are in (dynamic) blocks.
To edit those tables you can use BEDIT and then the function also works.
