Author Topic: gradient hatch color ByLayer  (Read 2421 times)
Matthew H
« on: January 22, 2018, 10:24:36 AM »
Is there a way to set a gradient hatch color to be "ByLayer", that way when a block's layer is changed the gradient color would change also?
Thank you,
Matthew H
Re: gradient hatch color ByLayer
« Reply #1 on: January 22, 2018, 10:37:17 AM »
I don't see a way to do it.
ChrisCarlson
« Reply #2 on: January 22, 2018, 10:46:35 AM »
I don't believe so as you need two different colors to complete the color gradient. By layer would be the same as a solid hatch.
Matthew H
« Reply #3 on: January 22, 2018, 10:59:14 AM »
I didn't see an option either...
I was thinking more along the lines of having "Color 1" set to "ByLayer" and "Color 2" set to 7.
