Author Topic: I keep getting a "bad point argument"  (Read 3582 times)
jlogan02
« on: December 29, 2017, 06:19:03 PM »
What is wrong with this bit of code?
bad point argument
(setq sca (getvar "dimscale"))
(setq pt1 (* sca 33.375))
(setq pt2 (* sca 21.4375))
(setq pt3 (* sca 31.375))
(setq pt4 (* sca 5.3125))
(ssget "CP" (list pt1 pt2 pt3 pt4))
J. Logan
ACAD 2016
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Ben Clark
Re: I keep getting a "bad point argument"
« Reply #1 on: December 29, 2017, 06:23:42 PM »
You have to pass ssget a list of points. You are passing it a list of real numbers.
jlogan02
« Reply #2 on: January 04, 2018, 12:37:07 PM »
I understand what you're saying, I'm just getting no where here, so I'll start at the beginning.
The coordinate points I listed are found in a title block revision history area. That title block has a dimscale of 1.0. I use those coordinate points to select all the text and lines within the revision history to;
a) to ensure the text or mtext is on a specific layer.
b) then copy the text and lines in the revision history out to the right of the border.
Now I want to multiply those coordinate points times the dimscale of a scaled drawing to copy out the revision history in them.
I can get the points and multiply them times the dimscale in my sleep now. What fail to do or understand is how take those multiplied coordinate points and create a list to get the points using crossing window or crossing polygon.
J. Logan
ACAD 2016
« Last Edit: January 04, 2018, 12:48:54 PM by jlogan02 »
J. Logan
ACAD 2018
« Reply #3 on: January 04, 2018, 12:44:37 PM »
Now I want to use that same idea but multiply those coordinate points times the dimscale of a scaled drawing to copy out the revision history in them.
The issue is that your 'multiplied points' are not points at all, they are simply numbers - the expression:
Will return a single number, not a list of two or three numbers constituting a point.
If you already have a set of point variables (e.g. pt1, pt2, pt3, pt4), you can scale the points (from the origin) by multiplying each of the coordinate values by your scale factor, e.g.:
(mapcar '(lambda ( x ) (* x sca)) pt1)
Or:
(mapcar '* pt1 (list sca sca sca))
Or, more explicitly:
(setq pt1 (list (* (car pt1) sca) (* (cadr pt1) sca) (* (caddr pt1) sca)))
jlogan02
« Reply #4 on: January 04, 2018, 01:06:49 PM »
Hi Lee,
Thanks for the quick response.
I had originally done this for a drawing with a dimscale of 8...
(setq Rev1 (mapcar '(lambda (x)(* x 8))'(31.875 5.3125 33.375 21.4375))
I didn't try to separate the points out
Once I do that how do I do this...
(command "_change" Rev1 "" "p" "la" "Text2" "")
Or is there a better way?
Something like this but not entlast...
(setq en1 (entlast))
  (setq ed (entget en1))
  (setq ed (subst (cons 8 "Text2") (assoc 8 ed) ed))
(entmod ed)
(setvar "cmdecho" 0)
J. Logan
ACAD 2016
J. Logan
ACAD 2018
jlogan02
« Reply #5 on: January 04, 2018, 01:10:42 PM »
I kept reading the help files to say that car, cadr, and caddr were user selected points. It can be used for both user input and known points?
J. Logan
ACAD 2016
J. Logan
ACAD 2018
« Reply #6 on: January 04, 2018, 01:36:16 PM »
I don't understand what the numbers in your example are referring to? - i.e. what are (31.875 5.3125 33.375 21.4375)?
This is evidently not a point, and the mapcar expression will simply return a list of 4 numbers multiplied by 8.
Yes, assuming your variable 'Rev1' will eventually be assigned a selection set, you can iterate over the selection set to have more control over the objects you are modifying.
car, cadr, and caddr are not points at all - they are AutoLISP functions which may be used respectively to retrieve the first, second, and third elements of a list. As such, when supplied with a list representing a set of coordinate values, (car <list>) will return the x-coordinate, (cadr <list>) the y-coordinate, and (caddr <list>) the z-coordinate.
I think you would benefit from reading these posts/tutorials:
http://ronleigh.com/autolisp/ales11.htm
http://www.theswamp.org/index.php?topic=39025.msg442238#msg442238
http://www.theswamp.org/index.php?topic=45131.msg503433#msg503433
http://www.theswamp.org/index.php?topic=31473.0
jlogan02
« Reply #7 on: January 04, 2018, 01:50:41 PM »
Sorry about that. I should have stated those are coordinate points that would represent the lower left and upper right of a window, crossing or other wise.
I am trying to select everything inside those coordinates. Those coordinates are found in the revision history area of a drawing with a dimscale of 1.0
If I know those points I should be able to multiply them times the dimscale of any drawing to select the objects found within those coordinates * dimscale.
31.875 5.3125 = Lower right corner of window
33.375 21.4375 = Upper right corner of window
J. Logan
ACAD 2018
« Reply #8 on: January 04, 2018, 02:07:17 PM »
OK, but in the current list structure, they are not points.
You have a couple of options here:
The points could be expressed as separate variables, e.g.:
(setq pt1 '(31.875 5.3125)
      pt2 '(33.375 21.4375)
And then scaled from the origin by the dimscale using:
(setq dim (getvar 'dimscale)
      pt1 (mapcar '* pt1 (list dim dim))
      pt2 (mapcar '* pt2 (list dim dim))
And then supplied to the ssget function in the following way:
(ssget "_C" pt1 pt2)
Or alternatively, expressed as a single list of points:
(setq lst '((31.875 5.3125) (33.375 21.4375))
Then (car lst) would yield the lower-left corner, and (cadr lst) would yield the upper-right.
Scaling these coordinates from the origin by the dimscale would be then achieved using:
      lst (mapcar '(lambda ( x ) (mapcar '* x (list dim dim))) lst)
This list of window points could then be supplied to the ssget function in the following way:
(apply 'ssget (cons "_C" lst))
Ben Clark
« Reply #9 on: January 04, 2018, 02:07:49 PM »
jlogan42,
You are still missing the underlying problem here that has been pointed out twice.
Number are not points, they're numbers. In autolisp, points are expressed as either a 2 or 3 element long list. i.e.
This is a number:
5
This is a 2d point:
(5 5)
This is a 3d point:
(5 5 5)
This is how you define a 3d point:
(setq pt1 (list 5 5 5))
or alternatively
(setq pt1 '(5 5 5))
pt1 is now a variable holding a point where x=5, y=5, z=5
The following defines a number, not a point
(setq a 5)
"a" is now a variable holding the number 5
When you're using ssget with "CP" as its first argument, it then expects to find a list of points as its next argument.
A list of points could be defined like this:
(setq ptlist (list (list 1 2 3) (list 4 5 6) (list 7 8 9))
You could also use the quote symbol. Read Lee Mac's write up on using it:
http://www.lee-mac.com/quote.html
This is why you're getting an error when using ssget. Hopefully this clears it up.
« Reply #10 on: January 04, 2018, 03:24:10 PM »
A friendly reminder to the more experienced users of this forum to use the custom code tag we worked so hard implementing into this forum whenever you can (or when/are offering help). The improved code tags allow newer users to get help on Autolisp functions by selecting the hyperlinks.
https://www.theswamp.org/index.php?topic=48309.0
EDIT: Or you can also pass along a hyperlink to a function with the following url syntax.
EG:
SSGET: http://www.theswamp.org/~john/avlisp/#ssget
jlogan02
« Reply #11 on: January 08, 2018, 03:17:28 PM »
Thanks Lee and Ben for straightening me out. Much appreciated.
J. Logan
ACAD 2016
J. Logan
ACAD 2018
