Author Topic: Grread - dynamic sizing/position of circle  (Read 7344 times)
Marc'Antonio Alessi
  • Marco
Re: Grread - dynamic sizing/position of circle
« Reply #15 on: February 06, 2017, 01:01:26 PM »
I seem to remember that AutoCAD does not support the method using entmod with only the entity name for all entities...
Correct - but Circles are supported.
I have this in my notes:
TYPE      MODIFIED USING ONLY ENAME?
ARC                   YES
ATTRIB (SINGLE)       YES
ATTRIB (MULTI)        NO
CIRCLE                YES
ELLIPSE               NO
HATCH                 NO
INSERT                YES
LINE                  YES
LWPOLYLINE            NO
MTEXT                 NO
POINT                 YES
POLYLINE              YES
SPLINE                NO
TEXT                  YES
XLINE                 NO
Thanks, are the new entities after about 2000...
ATTRIB (MULTI)    NO
ELLIPSE               NO
HATCH                 NO (maybe new type of)
LWPOLYLINE        NO
MTEXT                 NO
SPLINE                NO
XLINE                 NO
« Reply #16 on: February 06, 2017, 02:36:21 PM »
... internally invokes vle-entmod | entmod appropriately.
Yes maybe it is the best solution ... but I seem to remember that AutoCAD does not support the method using entmod with only the entity name for all entities...
Marc'Antonio Alessi
  • Marco
« Reply #17 on: February 06, 2017, 03:58:35 PM »
:yes:
Marc'Antonio Alessi
  • Marco
« Reply #18 on: February 07, 2017, 10:15:56 AM »
I do not know if the game's not worth the candle but I have discovered that Bricscad return nil if vle-entmod fail on New entities:
(defun ALE_EntMod (EntNam NewLst / Entdat)
    ( vle-entmod (vle-entmod (car NewLst) EntNam (cdr NewLst)) ); Bricscad return nil if fail
    ( (entmod (list (cons -1 EntNam) NewLst)) )                 ; Old entities
    ( (setq Entdat (entget EntNam))                             ; New entities
      (entmod (subst NewLst (assoc (car NewLst) EntDat) EntDat))
    ) ;this condition is not used because entmod do not return nil if fail
(defun Dxf (DxfCod EntDat)  (cdr (assoc DxfCod EntDat)))
(defun C:TestEntMod  ( / EntNam EntDat New040)
  (setq
    EntNam (car (entsel))
    EntDat (entget EntNam)
    New040 (1+ (DXF 40 EntDat))
  (print (DXF 0 EntDat))
  (print (DXF 40 EntDat)) (princ " Old Value")
  (print New040)          (princ " New Value")
  (ALE_EntMod EntNam (cons 40 New040))
  (print (DXF 40 (entget EntNam))) (princ " Real Value\n")
AutoCAD:
Comando: TestEntMod
Selezionare oggetto:
"CIRCLE"
18.0  Old Value
19.0  New Value
19.0  Real Value
Comando:  TestEntMod
"ELLIPSE"
0.603314  Old Value
1.60331   New Value
0.603314  Real Value
Bricscad
: TESTENTMOD
Select entity:
"CIRCLE"
19.0  Old Value
20.0  New Value
20.0  Real Value
: TESTENTMOD
Select entity:
"ELLIPSE"
0.603313750533175  Old Value
1.60331375053317   New Value
0.603313750533175  Real Value
roy_043
  • BricsCAD 18
« Reply #19 on: February 07, 2017, 10:23:44 AM »
How does your code use this fact? And does this really only apply to new entities?
Marc'Antonio Alessi
  • Marco
« Reply #20 on: February 07, 2017, 10:52:22 AM »
My pseudo code fail on new entities as vle-entmod return nil if fail
roy_043
  • BricsCAD 18
« Reply #21 on: February 07, 2017, 04:21:42 PM »
But vle-entmod works on both 'old' and 'new' entities and your code does nothing with the return value from that function.
Marc'Antonio Alessi
  • Marco
« Reply #22 on: February 07, 2017, 05:08:27 PM »
Ok, my apologies. I have found my error: (1+ (cdr (assoc 40 EntDat)) >>> 1+ is too big value for the ellipse!
Grazie.  :oops:
This is a better test:
(defun C:TestEntMod  ( / EntNam EntDat New062)
  (setq
    New062 (1+ (DXF 62 EntDat))
  (print (DXF 62 EntDat)) (princ " Old Value")
  (print New062)          (princ " New Value")
  (ALE_EntMod EntNam (cons 62 New062))
  (print (DXF 62 (entget EntNam))) (princ " Real Value\n")
Marc'Antonio Alessi
  • Marco
« Reply #23 on: February 08, 2017, 03:19:10 AM »
I have founfd the original code of Bricscad:
;;|              Copyright © Menhirs NV. All rights reserved.                    |
;; VLE Library Emulation for AutoCAD 2000 and higher, and for all BricsCAD versions
;;| FUNCTION : vle-entmod                                                        |
;;| (vle-entmod dxf ename value)                                                 |
;;| modifies the entity's property value for specified DXF group code;           |
;;| in typical case, this is a high-performance replacement for usual code like  |
;;| (entmod (subst (cons dxf value) olditem lst))                                |
;;| Arguments : 'dxf'   the DXF group code to set the new value for              |
;;|           : 'ename' the entity's ename                                       |
;;|           : 'value' new value to be set for the entity's property            |
;;| Return    :  T   if the entity's value has been updated (or is identical)    |
;;|              NIL if updating the entity's DXF value failed                   |
;;| Example   :  (vle-entmod 62 entity 112) sets the colour index as 112         |
(if (not vle-entmod)
  (defun vle-entmod ( dxf ename value / olditem lst )
    (if (setq lst (entget ename))
      (if (setq olditem (assoc dxf lst))
        (if (not (equal value (cdr olditem)))
          (and (entmod (subst (cons dxf value) olditem lst)))
          t ;; new value is same as current value, do not update, to keep performance
        (and (entmod (append lst (list (cons dxf value)))))
So, it use always the old method with subst...
ScottMC
« Reply #24 on: September 02, 2021, 09:07:17 PM »
Anyone able to show me how to reveal/extract the working choice from the "cir" entity (the lst selected)? Did a bit of diggin but must need to convert or something. Entities do have value and wish find out how to work a snatch live (assoc 40 cdr ..somehow. Thanks again.
Consider that when updating the circle position, you are using the original DXF data, as opposed to the DXF data which may hold a different radius value.
I would personally suggest:
  1. (defun c:gg ( / cir ent grr lst rad sel )
  2.     (setq lst
  3.        '(
  4.             (49 . 12.78)
  5.             (50 . 15.78)
  6.             (51 . 18.78)
  7.             (52 . 21.78)
  8.         )
  9.     )
  10.     (if (setq sel (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
  11.         (progn
  12.             (setq ent (ssname sel 0)
  13.                   cir (cons -1 (entmakex (list '(0 . "CIRCLE") '(10 1e8 1e8) (cons 40 (cdar lst)))))
  14.             )
  15.             (while (/= 3 (car (setq grr (grread t 15 0))))
  16.                 (cond
  17.                     (   (= 5 (car grr))
  18.                         (entmod (list cir (cons 10 (vlax-curve-getclosestpointto ent (cadr grr)))))
  19.                     )
  20.                     (   (= 2 (car grr))
  21.                         (if (setq rad (cdr (assoc (cadr grr) lst)))
  22.                             (entmod (list cir (cons 40 rad)))
  23.                         )
  24.                     )
  25.                 )
  26.             )
  27.         )
  28.     )
  29.     (princ)
  30. )
Note that the above is only a draft and doesn't account for UCS/Views etc.
« Last Edit: September 12, 2021, 06:31:53 PM by ScottMC »
