Author Topic: Find Line Spaces in Block  (Read 2557 times)
One Shot
« on: May 17, 2005, 10:41:11 AM »
Is there a lisp out there in the Swamp world that can find any lines that are not closed? This lisp should ID the areas that are closed. This will help in fixing the block quickly.
Example:
You have block and you hatch. The hatch intrudes on the block. You have set the hatch Gap tolerance 1 and the hatch still intrudes.
Thank you,
Brad
« Reply #1 on: May 17, 2005, 10:47:27 AM »
Hello, welcome to Portal 42.
Please press (1) for TheSwamp, press (2) For AUGI.
  • Custom Title
« Reply #2 on: May 17, 2005, 10:51:52 AM »
*chuckle* I think you're being picked on Brad.
Quote from: Brad (aka One Shot)
Is there a lisp out there in the Augi world
One Shot
« Reply #3 on: May 17, 2005, 10:58:02 AM »
Sorry about that.  I use both for help and to learn.
Brad
« Reply #4 on: May 17, 2005, 11:18:21 AM »
No worries Brad, I just thought it was a funny post to make here.
  • Custom Title
« Reply #5 on: May 17, 2005, 11:18:39 AM »
What adesk product are you using Brad?
One Shot
« Reply #6 on: May 17, 2005, 11:20:00 AM »
I am using AutoCAD 2005 / ADT2005.
« Reply #7 on: May 17, 2005, 11:23:08 AM »
Here's a start: This should find all polylines (lightweight and traditional) that are not closed:
(ssget "x"
   '(   (0 . "lwpolyline,polyline")
        (-4 . "<not")
        (-4 . "&")
        (70 . 1)
        (-4 . "not>")
One Shot
« Reply #8 on: May 17, 2005, 11:36:40 AM »
Can this be changes to find just lines also?
daron
« Reply #9 on: May 17, 2005, 11:41:04 AM »
When is a line closed? You can use the close prompt when drawing it, but that isn't like a pline, where it's an open or closed polygon. In line, it's just a prompt, not a property.
