Author Topic: Area Calculation Table  (Read 1858 times)
GDF
« on: July 31, 2016, 02:10:34 PM »
I have found two hatch area label routines to use as examples:
;;http://www.theswamp.org/index.php?topic=35609.new
;;By Juan Villarreal
;;http://www.lee-mac.com/arealabel.html
;;AreaLabelV1-9.lsp
;;by LeeMac
My goal is to modify my code below to label the hatch areas in lieu of numbering them as per the codes above.
Here is what I am currently using below; where I have to do a lot of manual picking. I would like the automation process
of the the two examples above, in lieu of creating the Area Calculation Table.
Please refer to the Picture posted.
(defun SelectAreaObject (/ SFOBJ obj ObjLayerName ObjLayer)
  (setq SFOBJ (entsel "\n* Select Object To Get Area of *"))
  (setq obj (entget (car SFOBJ)))
  (setq ObjLayer (cdr (assoc 8 Obj)))
  (if (> (strlen ObjLayer) 7)(setq ObjLayerName (substr ObjLayer 8 (- (strlen ObjLayer) 4))))
        ((= ObjLayerName "BRCK")(setq ARCH#NAM "Brick Masonry"))
        ((= ObjLayerName "CBRK")(setq ARCH#NAM "Cultured Brick"))
        ((= ObjLayerName "CSTN")(setq ARCH#NAM "Cultured Stone"))
        ((= ObjLayerName "STON")(setq ARCH#NAM "Stone Masonry"))
        ((= ObjLayerName "SIDE")(setq ARCH#NAM "Hardie Siding"))
        ((= ObjLayerName "PLAS")(setq ARCH#NAM "Cement Plaster"))
        ((= ObjLayerName "METL")(setq ARCH#NAM "Metal Siding"))
        ((= ObjLayerName "HEAT")(setq ARCH#NAM "Heated Living Area"))
        ((= ObjLayerName "GARG")(setq ARCH#NAM "Garage/ Stair"))
        ((= ObjLayerName "OLIV")(setq ARCH#NAM "Outdoor Living"))
        ((= ObjLayerName "PORC")(setq ARCH#NAM "Porch"))
        ((= ObjLayerName "STOR")(setq ARCH#NAM "Storage"))
        ((= ObjLayerName "COCH")(setq ARCH#NAM "Porte Cochere"))
        ((= ObjLayerName "")(setq ARCH#NAM "Area"))
  (command "AREA" "o" SFOBJ)
  (princ))
(defun ERROR-SSF ()
  (ARCH:MsgBox2
    " Arch Program : Error"
    16
     Pick Error : SFF
     You did NOT Pick on the Table!
     Pick Location for Text in [ Area Calculation Table ]
     Please try again...
  " 4
(defun SFFit (/ apoint sqftx atext1 atext2)
  ;;(ARCH:F_S-VAR)
  (setvar "osmode" 2)
  (SelectAreaObject)
  (setq APOINT (osnap (getpoint "\n* Pick Location for Text in Area Calculation Table *") "Mid"))
  (while (= APOINT nil)
      (ERROR-SSF)
      (setq APOINT (osnap (getpoint "\n* Pick Location for Text in Table *") "Mid"))
  (setq SQFTX (/ (getvar "AREA") 144))
  (setq ATEXT1 (strcat "" (rtos SQFTX 2 (atoi ARCH#DECI)) " S.F.   "))
  (setq ATEXT2 (strcat "     " ARCH#NAM))
  ;;(ARCH:LYR "A-SYMB")
  ;;(ARCH:SET-ARIAL)
  (command "text" "j" "mr" APOINT ARCH#SC-A 0 ATEXT1)
  (setq SSET (ssadd (entlast) SSET))
  (command "text" "j" "ml" APOINT ARCH#SC-A 0 ATEXT2)
  (setq SFOBJ nil apoint nil)
  ;;(ARCH:F_R-VAR)
  (princ))
(defun C:SFF ()
  (setq SSET (ssadd))
  (SFFit)
  (while (= SFOBJ nil)(SFFit))
  (princ))
(defun C:ASF (/ s1 lg index count c x a d atext3 atext4 totalarea apoint2)
  ;;(ARCH:F_S-VAR)
  (setq APOINT2 (getpoint "\n* Pick Location for Text in Table *"))
  (setq S1 SSET
        ;;S1 (ssget)
        LG    (sslength S1)
        INDEX 0
        COUNT 0
        C     0)
  (while (/= INDEX LG)
    (setq X (ssname S1 INDEX)
          A (entget X)
          D (cdr (assoc 0 A)))
    (if (= D "TEXT")
      (progn (setq B     (atof (cdr (assoc 1 A)))
                   C     (+ C B)
                   COUNT (1+ COUNT))))
    (setq INDEX (1+ INDEX)))
  (setq TOTALAREA (rtos C 2 (atoi ARCH#DECI)))
  (setq ATEXT3 (strcat "" TOTALAREA " S.F.   "))
  (setq ATEXT4 (strcat "    " " Total Slab Area "))
  ;;(ARCH:SET-ARIAL)
  (command "text" "j" "mr" APOINT2 ARCH#SC-A 0 ATEXT3)
  (command "text" "j" "ml" APOINT2 ARCH#SC-A 0 ATEXT4)
  (setq SSET nil)
  ;;(ARCH:F_R-VAR)
  (princ))
« Last Edit: July 31, 2016, 02:13:36 PM by GDF »
GDF
Re: Area Calculation Table
« Reply #1 on: August 01, 2016, 06:54:48 PM »
I decided to go the attributed block route. This is more in my abilities.
GDF
« Reply #2 on: August 02, 2016, 04:39:43 PM »
Well for what it's worth...here is my final results:
 :idea:
danallen
« Reply #3 on: August 02, 2016, 07:48:53 PM »
thanks for sharing, need to embark on site area diagram myself soon. Your lisp is missing some helper routines? for example ARCH:ATTUPDATE
Dan
GDF
« Reply #4 on: August 03, 2016, 10:03:21 AM »
;; EN   entity name of insert
;; TAG  attribute tag
;; NEW  new attribute value [string]
;; Replaces current attribute value stored in
;; drawing with the NEW string value.
(defun ARCH:ATTUPDATE  (EN TAG NEW / EL)
  (setq EN (entnext EN)
        ;;skip INSERT
        EL (entget EN)
           ;;get ATTRIB
  ;; Search attribs for match of tag name
  (while (and (= (cdr (assoc 0 EL)) "ATTRIB") (/= (cdr (assoc 2 EL)) TAG))
          ;;next ATTRIB
          EL (entget EN)))
  (if (= (cdr (assoc 0 EL)) "ATTRIB")
    (progn (entmod ;;modify entity data
                   (subst ;;substitute in list
                          (cons 1 NEW)
                          ;;new data
                          (assoc 1 EL)
                          ;;old data
                          EL
                          ;;list
           (entupd EN)
           ;;force regen of entity
