Author Topic: Civil 3D | Dual Pipe Networks  (Read 3578 times)
BlackBox
« on: May 06, 2016, 10:24:10 AM »
Any way to adjust (or draw?) a parallel Pipe Network at the same respective elevations as the adjacent Pipe Network, without manually adjusting in Profile View?
As example: I have a pair of chilled water mains (supply/return) that are being piped throughout a college campus, dorms, etc. to connect to their HVAC. I've already done the first Pipe Network, and am only showing that in Profile View with 'dual' labels, adjusting critical parts at crossings, etc., for expediency... But I will ultimately need to have them both 'in-line' for later plan sheets.
Cheers
Re: Civil 3D | Dual Pipe Networks
« Reply #1 on: May 06, 2016, 11:02:48 AM »
TRY...
draw first network..
export to land XML
edit it to the 'parallel' location
RENAME the network
import the one you exported above
BlackBox
« Reply #2 on: May 06, 2016, 12:17:07 PM »
Thanks, MJF - that's still a LOT of work though (multiple miles of pipes)
I may just create a Alignment+Profile from the Pipe's crown, extract a Feature Line, offset that, and the create a Pipe Network from the offset Feature line, but I still need to modify a LOT of Null Structures (assigning a Tee, 45, BFV, etc style). :|
« Reply #3 on: May 06, 2016, 12:20:34 PM »
ALTERNATELY
Use a corridor...one can A) use polyline object for custom assembly, or B)use generic links to make the pipes...
MSTG007
« Reply #4 on: May 06, 2016, 12:33:12 PM »
I like that idea...
Civil3D 2020
nobody
  • .net stuff
« Reply #5 on: May 06, 2016, 03:46:07 PM »
Seems like .net could help...but if you're like me...sometimes it's just easier to adjust things...if I hardly ever do that task anyway.
