Author Topic: Locate block within multiple layouts  (Read 1707 times)
Biscuits
« on: March 30, 2016, 11:23:22 AM »
Using Acad2015 Windows 7 (64) bit
Any ideas for a simple method to locate a block within a drawing that has multiple layouts?
QSelect appears to only work in the current layout.
Any advice would be helpful. Thanks
Re: Locate block within multiple layouts
« Reply #1 on: March 30, 2016, 11:39:05 AM »
what are you trying to do to this block?
« Reply #2 on: March 30, 2016, 11:45:37 AM »
Assuming it's not a modified dynamic block:
  1. (SSSETFIRST nil (ssget "_x" (list '(0 . "insert") (cons 2 "blockname"))))
Then change what you want in the properties box.
Biscuits
« Reply #3 on: March 30, 2016, 11:47:49 AM »
MJ  Looking to locate and possibly explode it.
« Reply #4 on: March 30, 2016, 12:02:38 PM »
that's not nice...
why not just block edit it instead?
this would update all instances of the block without you locating it
Biscuits
« Reply #5 on: March 30, 2016, 12:43:34 PM »
Basically, some items in our older drawings should never have been blocks in the first place.
My employer wants/insists these blocks be exploded. Example: a line of text or a simple line. Some of these older blocks contain extraneous data that mess up file management software that renders PDFs from the drawings when checked into the system. The data should have been purged from the original block but still remain. So, if I'm trying to find a block called "TIC"
I have to find where in the drawing it is located then determine if it should be exploded. Trust me it is more involved than that.
But, for now I am looking for a way to locate which layout (s) contain the block in question. Qselect is great only for the current layout and some of our file may have 30 layouts or more. Thank you ronjonp for the code, but it does not direct me to the layout (s). Block edit is not an option.
Thanks for the help, gang!
ChrisCarlson
« Reply #6 on: March 30, 2016, 01:16:06 PM »
  1. (defun c:explodeTIC ( / ss)
  2.         (if
  3.                 (setq ss (ssget "_x" (list (cons 0 "INSERT") (cons 2 "TIC"))))
  4.                         (progn
  5.                                 (command "_.explode" ss)
  6.                                 (princ (strcat (itoa (sslength ss))" Blocks Exploded"))
  7.                         )
  8.                         (princ "\nNo Blocks Found")
  9.         )
  10.         (princ)
  11. )
  12.
Biscuits
« Reply #7 on: March 30, 2016, 01:21:10 PM »
Thanks for the effort Chris. I already have a similar routine. But. I have to locate the blocks first for a visual then only possibly explode.
It's the finding of the block I need.
« Reply #8 on: March 30, 2016, 01:26:46 PM »
This will print the tabname to the command line where the blocks are found.
  1. (defun c:foo (/ ss)
  2.   (if (setq ss (ssget "_x" (list '(0 . "insert") '(2 . "TIC"))))
  3.     (mapcar '(lambda (b) (print (cdr (assoc 410 (entget b))))) (mapcar 'cadr (ssnamex ss)))
  4.   )
  5. )
« Last Edit: March 31, 2016, 08:22:00 AM by ronjonp »
« Reply #9 on: March 30, 2016, 01:29:32 PM »
When you know the layout, this may help you locate all references of the block:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/to-find-amp-mark-blocks-via-lisp/m-p/4715139#M318045
ChrisCarlson
« Reply #10 on: March 30, 2016, 02:05:25 PM »
  2.         (if
  4.                         (progn
  7.                         )
  9.         )
  10.         (princ)
  11. )
  12.
Actually, testing this code it only explodes in the current space.
Biscuits
« Reply #11 on: March 30, 2016, 02:13:44 PM »
ronjonp's FOO code comes closest to what I need. I can make this work.
Big thank you to everyone for their efforts. You guys are awesome.
Thanks again
« Reply #12 on: March 30, 2016, 02:47:05 PM »
Glad to help :)
Marc'Antonio Alessi
  • Marco
« Reply #13 on: March 31, 2016, 03:57:44 AM »
Why not create clean blocks on separate DWG files and then insert them with "insert="  ?
