It says here (http://www.poweranalytics.com/paladin-software/paladin-designbase/) that it is compatible.
Unfortunately since both programs are based off the same programming code there isn’t a known workaround. Some customers are able to work with both applications installed however they experience sporadic application crashes or runtime errors. Therefore we recommend saving often if you attempt to have both installed on the same computer. You can also try opening up the program you wish to run first after a system restart which should allocate the system resources to that application. Setting DesignBase to run as administrator can also help it access the resources it needs to run. You can do this by right clicking on the shortcut to the application, selecting properties, clicking the compatibility tab, and selecting always run as administrator
Also note that DesignBase will need to be installed on a machine that doesn’t have Actrix based software such as AutoCAD or AutoDRAW. This is because DesignBase has the same base code and will attempt to use the same system resources.
QuoteUnfortunately since both programs are based off the same programming code there isn’t a known workaround. Some customers are able to work with both applications installed however they experience sporadic application crashes or runtime errors. Therefore we recommend saving often if you attempt to have both installed on the same computer. You can also try opening up the program you wish to run first after a system restart which should allocate the system resources to that application. Setting DesignBase to run as administrator can also help it access the resources it needs to run. You can do this by right clicking on the shortcut to the application, selecting properties, clicking the compatibility tab, and selecting always run as administratorQuoteAlso note that DesignBase will need to be installed on a machine that doesn’t have Actrix based software such as AutoCAD or AutoDRAW. This is because DesignBase has the same base code and will attempt to use the same system resources.
