Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
2D ISOMETRIC HELP OR MIRROR LISP
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 2D ISOMETRIC HELP OR MIRROR LISP (Read 2409 times)
notredave
Newt
on:
March 07, 2016, 05:52:44 PM »
All,
Can someone help me mirror this iso drawing attached? I need the "tee" on the other side on the same plane. Are there any lisp routines out there that does this. Your help is greatly appreciated.
Thank you,
David
Logged
Seagull
Every Student their own Lesson
WWW
Re: 2D ISOMETRIC HELP OR MIRROR LISP
Reply #1 on:
March 07, 2016, 06:03:00 PM »
suggest attach this as xref
rotate about z and trace
Logged
Rob...
King Gator
Take a little time to stop and smell the roses.
Reply #2 on:
March 08, 2016, 06:59:26 AM »
I tried doing it manually just to see how long it would take. I should have been able to do it in a matter of a minute or three including getting my head around the part. I was going to copy the pieces matching the distances from center and make a few adjustments for new view. It was not as easy as it should have been because the original is not quite accurate.
Logged
CAD Tech
notredave
Newt
Reply #3 on:
March 08, 2016, 07:45:50 AM »
Thank you for trying Rob. I just thought there would be a lisp routine out there to mirror an isometric. I will keep looking for a solution.
Logged
Rob...
King Gator
Reply #4 on:
March 08, 2016, 07:49:16 AM »
If it were drawn correctly, it would be very easy. I'm afraid that a lisp wouldn't be able to interpolate through the errors in order to give you satisfactory results.
Logged
CAD Tech
Seagull
WWW
Reply #5 on:
March 08, 2016, 09:09:31 AM »
except for the original errors...not fixing them....this was about 5 minutes
one can make it appear correct with a little adjustment
Logged
notredave
Newt
Reply #6 on:
March 08, 2016, 09:16:27 AM »
mjfarrell,
Thank you very much! I can work with this drawing. Many thanks again!
David
Logged
Seagull
WWW
Reply #7 on:
March 08, 2016, 09:46:36 AM »
of interest, this type of stuff is often easier to model in 3d, and then extract ISO views from the model
Logged
notredave
Newt
Reply #8 on:
March 08, 2016, 10:20:30 AM »
mjfarrell, I have no experience modeling in 3D but thank you again!
David
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
