Author Topic: Error with SaveFileDialog  (Read 1837 times)
Coder
« on: February 17, 2016, 01:46:50 AM »
Hello guys.
It seems that I can't make an instance of SaveFileDialog ! and it requires to feed it with the arguments as in the attached image.
Is there any work around this error?
Thanks a lot.
edit:kdub->fixed post title
« Last Edit: February 17, 2016, 03:20:55 AM by kdub »
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Error with SvaeFileDialog
« Reply #1 on: February 17, 2016, 02:03:41 AM »
The SaveFileDialog constructor does not take parameters.
New the SaveFileDialog () then set properties.
https://msdn.microsoft.com/en-us/library/system.windows.forms.savefiledialog(v=vs.110).aspx
Called Kerry in my other life
I live at UTC + 13.00
Coder
« Reply #2 on: February 17, 2016, 02:09:54 AM »
Yes,
I wonder why it gives me that error message this time !
kdub_nz
  • SuperMod
Re: Error with SaveFileDialog
« Reply #3 on: February 17, 2016, 02:13:30 AM »
Silly me , I assumed you meant the System.Windows.Forms.SaveFileDialog()
Did you mean Autodesk.AutoCAD.Windows.SaveFileDialog
I should have guessed that.
Provide more detail about what doesn't work for you .
edit:fixed post title
« Last Edit: February 17, 2016, 02:27:12 AM by kdub »
kdub_nz
  • SuperMod
« Last Edit: February 17, 2016, 02:31:04 AM by kdub »
Coder
« Reply #5 on: February 17, 2016, 02:36:30 AM »
Not silly at all but that is the truth  :wink:
I confused between the two SvaeFileDialog methods, Windows and AutoCAD. sorry for that.
I added the full path of the NameSpace System.Windows.Forms.SaveFileDialog svd ..... and that 's what I was after.
Many thanks Kerry for your prompt help.
And thanks for the links , they look great and very informative.
kdub_nz
  • SuperMod
« Reply #6 on: February 17, 2016, 02:49:42 AM »
