Author Topic: What's this message mean?  (Read 3660 times)
HasanCAD
« on: July 29, 2015, 03:53:38 PM »
While converting block to xref using blocktoxref this message comes.
Matt__W
  • I like my water diluted.
Re: What's this message mean?
« Reply #1 on: July 29, 2015, 04:04:23 PM »
>>LINK<<
Autodesk Expert Elite
« Reply #2 on: July 29, 2015, 04:06:34 PM »
It means someone has done this:
  1. (setq gc ... )
HasanCAD
« Reply #3 on: July 29, 2015, 05:06:51 PM »
  1. (setq gc ... )
So should I do this?
  1. (setq gc nil )
dgorsman
« Reply #4 on: July 29, 2015, 05:30:53 PM »
Ahhhh, NO.  "gc" is a named function ie. (gc) so it should *never* be used as a variable name.  Unless you are certain nothing you've got actually calls that function.  And even then its just a bad idea, like doing (setq defun nil).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
« Reply #5 on: July 29, 2015, 05:35:38 PM »
  1. (setq gc ... )
  1. (setq gc nil )
Definitely not - and you would receive the same error if you did; you should instead try to ascertain the source of the problem.
On a brief inspection of the code for the BLOCKTOXREF command, the issue seems to stem from the acet-blocktoxref-copy-layer-props function defined on line 233 of the blocktoxrefsup.lsp file: this function declares the symbol 'gc' as a local variable and uses this protected symbol within a foreach loop.
I would suggest replacing all occurrences of the symbol 'gc' between lines 233 & 277 with say, 'gcc' (or any unprotected symbol which hasn't already been used).
« Reply #6 on: July 29, 2015, 09:39:30 PM »
If you are not if it's a Function or Command or Variable try the command LSP
This only works for globally assigned Symbols ie will not recognise variables or methods local to a function.
Command: LSP
Initializing...
Enter an option [?/Commands/Functions/Variables/Load]: c
Enter Commands to list <*>: g*
GATTE                         (SUBR)
GETSEL                        (SUBR)
GIFIN                         (SUBR)
GOTOURL                       (SUBR)
Command:
Command: LSP
Enter an option [?/Commands/Functions/Variables/Load]: v
Enter Variables to list <*>: g*
GVAR:REACTORPREVLAYER         (STR)
Command:
Command: LSP
Enter an option [?/Commands/Functions/Variables/Load]: f
Enter Functions to list <*>: g*
GC                            (SUBR)                        Core
GCD                           (SUBR)                        Core
GET_ATTR                      (SUBR)                        Core
GET_TILE                      (SUBR)                        Core
GETANGLE                      (SUBR)                        Core
GETATOMS                      (SUBR)
GETATTRIBUTES                 (SUBR)
GETCFG                        (SUBR)                        Core
GETCNAME                      (SUBR)                        Core
GETCORNER                     (SUBR)                        Core
GETDIST                       (SUBR)                        Core
GETENV                        (SUBR)                        Core
GETFILED                      (SUBR)                        Core
GETINT                        (SUBR)                        Core
GETKWORD                      (SUBR)                        Core
GETORIENT                     (SUBR)                        Core
GETPOINT                      (SUBR)                        Core
GETPROPERTYVALUE              (EXRXSUBR)
GETREAL                       (SUBR)                        Core
GETSTRING                     (SUBR)                        Core
GETURL                        (EXRXSUBR)                    Core
GETVAR                        (SUBR)                        Core
GRAPHSCR                      (SUBR)                        Core
GRCLEAR                       (SUBR)                        Core
GRDRAW                        (SUBR)                        Core
GRREAD                        (SUBR)                        Core
GRTEXT                        (SUBR)                        Core
GRVECS                        (SUBR)                        Core
Command:
Also note that symbols can be assigned 'protected' from code.
;; if you answer NO to 'enter break loop'
;; the value of the protected symbol theNumber will be redefined.
;; Enter YES to 'enter break loop' for the value to be retained.
I use this a lot for a warning regarding symbols I don't want to be casually overwritten.
Note that the Symbol names will turn blue in the Vlide after protection.
  1. ;; protect-assign sample : kdub 2015/07/30
  2.
  3. (eval (list 'pragma (list 'quote (list (cons 'unprotect-assign (list 'Function01 'Function02 'theNumber))))))
  4.
  5. (defun Function01 ()
  6.   (alert "This is Function 01")
  7.   (princ)
  8. )
  9.
  10. (defun Function02 ()
  11.   (alert "This is Function 02")
  12.   (princ)
  13. )
  14.
  15. (setq theNumber 42)
  16.
  17.
  18. (eval (list 'pragma (list 'quote (list (cons 'protect-assign (list 'Function01 'Function02 'theNumber))))))
  19.
  20. ;;=============================================================
  21.
  22. ;; NOTE : if you answer NO to 'enter break loop'
  23. ;; the value of the protected symbol theNumber will be redefined.
  24. ;; Enter YES to 'enter break loop' for the value to be retained.
  25. (setq theNumber 44)
  26.
« Reply #7 on: July 30, 2015, 04:06:13 AM »
  1. (eval (list 'pragma (list 'quote (list (cons 'unprotect-assign (list 'Function01 'Function02 'theNumber))))))
This seems unnecessarily complicated; why not the following?:
  1. (pragma '((unprotect-assign Function01 Function02 theNumber)))
(similarly for 'protect-assign')
« Reply #8 on: July 30, 2015, 05:03:53 AM »
Yes Lee, that will work in the instance shown. I just cut the names in for the sample rther than use a list of names as I usually do.
I allocate the function names and vars to a list of quoted names
This would be more slightly economical .. use a quoted list of names.
  1. (setq funs '(Function01 Function02 theNumber Function03 Function04 Function04 Function06 Function07 Function08 ;; etc etc))
  2.
  3. (eval (list 'pragma (list 'quote (list (cons 'unprotect-assign funs)))))
  4.
  5.
  6. ;; define / declare stuff here
  7.
  8.
  9. (eval (list 'pragma (list 'quote (list (cons 'protect-assign funs)))))
  10.
  11. (setq funs nil)
That methodology is essentially unchanged by me since Release R14 with VitalLisp by Basis Software (before AutoDesk purchased and modified the Software and renamed it VisualLisp )
« Reply #9 on: July 30, 2015, 05:30:34 AM »
Without wanting to labour the point, I still don't see the need for the (eval (list 'pragma ... )) construct - even with a list of symbols, I would use:
  1. (pragma (list (cons 'unprotect-assign funs)))
« Reply #10 on: July 30, 2015, 05:42:56 AM »
Did you try that Lee ??
« Reply #11 on: July 30, 2015, 05:54:35 AM »
No (no access to CAD at the moment) - just following the logic of what (list 'quote (list (cons 'unprotect-assign funs))) should return :wink:
HasanCAD
« Reply #12 on: August 02, 2015, 04:37:23 AM »
  1. Command: (pragma (list (cons 'unprotect-assign funs)))
  2. ; error: syntax error
