Author Topic: vba-to VSTA.vb  (Read 1611 times)
krampaul82
vba-to VSTA.vb
« on: July 28, 2015, 11:26:20 AM »
Hello Gurus
See attached.
Can any one help or nudge me in the right direction?
any help appreciated...
Atook
  • AKA Tim
Re: vba-to VSTA.vb
« Reply #1 on: July 28, 2015, 12:12:03 PM »
You want us to download an unknown word document related to VB stuff and open it on our machines?
If you post code, we can look at it. This is too close to real world attack vectors.
Maybe someone else can help you, I'll stand by the sidelines on this one...
/paranoid
krampaul82
Re: vba-to VSTA.vb
« Reply #2 on: July 28, 2015, 12:47:31 PM »
I attached the Docx to show the intent of the program... here is the typ form code and module code....
' Form    : Gartner_relay_main
' DateTime  : 11/15/2012 13:24
' Author    : Mark
' Purpose   : Code for GTC GUI To Get Commonly used Relay Blocks
'#### Kele RTE Timer Relays     ####
Private Sub cmd_kele_common_Click()
'ComboBox_kele_common Dropdown Menu
  ComboBox_kele_common.Style = fmStyleDropDownList
'Get ComboBox_kele_common Dropdown Menu user pick
  Select Case ComboBox_kele_common.Text
     Case "RTE-P1AD24"    'Calls sub from Module_omron
      Lbl_kele_common.Caption = "RTE-P1AD24"
       kele_rte_p1ad24_get
     Case "RTE-P2AD24"    'Calls sub from Module_omron
      Lbl_kele_common.Caption = "RTE-P2AD24"
       kele_rte_p2ad24_get
     Case "RTE-P1AF20"    'Calls sub from Module_omron
      Lbl_kele_common.Caption = "RTE-P1AF20"
       kele_rte_p1af20_get
     Case "RTE-P2AF20"    'Calls sub from Module_omron
      Lbl_kele_common.Caption = "RTE-P2AF20"
       kele_rte_p2af20_get
  End Select
End Sub
''@@@@@   Combo Box Choices Start  @@@
Sub UserForm_Initialize()
'' Combo box kele Sequencer / Relay Populate
   'ComboBox_kele_common Series Populate Choices
    ComboBox_kele_transducer_common.AddItem "UCS-221E"    'UCS-221E = 0 Case Selection
    ComboBox_kele_transducer_common.AddItem "UCS-421E"    'UCS-421E = 1 Case Selection
   'ComboBox_kele_transducer_common First item static
      ComboBox_kele_transducer_common.ListIndex = 0
' Module    : Module_Timer_Switch.
' DateTime  : 11/15/2012 11:38
' Author    : Mark
' Purpose   : This module holds all of the commands to go and get all of the
'             Kele Sequencer Relays
'             It will be easy to de-bug this way
'             enjoy the program.......MP
'#### Kele Sequencer Relays     ####
Sub kele_ucs_221e_get()
' Varibles for message box
Dim Msg, Style, Title, Ctxt, Response, MyString
Msg = Msg & "UCS-221E is a 24Vac/Vdc 2 Stage Sequencer Relay" & vbLf ' Define message.
Msg = Msg & "Snap Track Mounted Continue?" & vbLf ' Define message.
Style = vbYesNo + vbInformation + vbDefaultButton1    ' Define buttons.
Title = "UCS-221E"    ' Define title.
Ctxt = 1000    ' Define topic
        ' context.
        ' Display message.
Response = MsgBox(Msg, Style, Title, Help, Ctxt)
If Response = vbYes Then    ' User chose Yes.
'Change to model space if in paperspace
    ThisDrawing.ActiveSpace = acModelSpace
    Dim insertpoint(0 To 2) As Double
'Hide the window to get The Insertion Point
    Gartner_relay_main.hide
'get the origin
    ThisDrawing.Application.ActiveDocument.Activate
    returnPnt = ThisDrawing.Utility.GetPoint(, "Select Insert Point: ")
    insertpoint(0) = returnPnt(0)
    insertpoint(1) = returnPnt(1)
    insertpoint(2) = returnPnt(2)
'Insert the block
    Dim blockRefObj As AcadBlockReference
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(returnPnt, "v:\gtc_proj\ACAD_Blocks\Relays_Contactors\Kele\ucs-221e-01.dwg", 1#, 1#, 1#, 0)
'Quicker than a regen...
    ZoomAll
    ZoomPrevious
End
Else                ' User chose No.
End If
End Sub
