Author Topic: Close a spline?  (Read 5311 times)
CHulse
Re: Close a spline?
« Reply #15 on: July 17, 2015, 10:56:39 AM »
Frankly didn’t expect to see so much interest in this.
This is a test data set.
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Re: Close a spline?
« Reply #16 on: July 17, 2015, 11:07:48 AM »
Cool .. was just curious.
Pad
Re: Close a spline?
« Reply #17 on: July 20, 2015, 04:23:02 AM »
Let me know how it works for you - I have not tested it heavily.
Are you doing tree canopies also? if so, out of curiosity - what state are you in?
It looks to work well Cary.  I didn't use it this time, because I had a sub-contractor carry out the topo.  I popped back to measure the spreads and added them manually.  Next time I have a job with asymmetric spreads I will hopefully be making use of this.
Thanks P
CHulse
Re: Close a spline?
« Reply #18 on: July 20, 2015, 06:50:16 AM »
Thanks P
Glad to hear you can make use of it.
This code could be modified fairly easily to allow you to pick the point (i.e. tree trunk center) on screen from a topo survey vs. Pulling the points form the csv. I have a similar one I use for basic tree symbology.
This is a snippet from my other tool where it gets the point from user input instead of the csv.
     (while (and (setq x  (car *lst*))
                  (setq pt (getpoint "\nSpecify Point for Block: ")))
(if (vl-catch-all-error-p
              (setq OBJ
                (vl-catch-all-apply (function vla-InsertBlock)
                  (list spc (vlax-3D-point (trans pt 1 0)) bNme 1. 1. 1. *ROT*))))
          (princ "\n** Error Inserting Block **")
Cary Hulse
