Author Topic: Attribs: Dynamic Visibility versus GroupCode 60  (Read 3360 times)
Peter2
« on: April 13, 2015, 09:11:28 AM »
I talked with an Acad user who has many dynamic blocks where the dynamic-features are only used to modify the visibility of the attribs. Now I'm thinking about the pros and cons of using groupcode 60 (visibility) instead of dynamic feature.
Con:
- needs a special tool (Lisp ...) and
- needs a special handling
Pro:
- can be used also without dynamic block
- can be used regardless of the name of visiblity-status
- can be used in old Acadversions
- does not create a bunch of "*U-blocks"
- the tool can be used for other features too
It seems that I oversaw some cons - but which? "Of course "Dynamic" can be used for much more, but if it is reduced only to the mentioned usage?
What's your opinion about this approach?
Peter
BricsCAD V23
Re: Attribs: Dynamic Visibility versus GroupCode 60
« Reply #1 on: April 13, 2015, 09:30:50 AM »
Aside, note that dynamic blocks also use the DXF 60 group code to control the visibility of objects within the block definition.
« Last Edit: April 13, 2015, 09:57:07 AM by Lee Mac »
owenwengerd
« Reply #2 on: April 13, 2015, 10:45:04 AM »
Dynamic blocks are the spawn of Satan and should be avoided at all costs. The visibility states feature is especially prone to abuse by end users. As a developer you should never sell your soul to dynamic blocks.
Peter2
« Reply #3 on: April 13, 2015, 11:09:31 AM »
Dynamic blocks are the spawn of Satan and should be avoided at all costs...
The clarity of this response is impressive .. :-)
(Do you have some links summing up this topic?)
Peter
BricsCAD V23
« Reply #4 on: April 13, 2015, 11:43:45 AM »
Since you are only looking to control the visibility of attributes, rather than using the generic visibility property (i.e. DXF Group 60) you could instead use the invisible property of an attribute reference, which could be reverted manually using ATTSYNC if necessary.
To offer an example, attached is an old program following this approach (please excuse my old & ugly code formatting).
Lee
Peter2
« Reply #5 on: April 13, 2015, 12:18:28 PM »
Hi Lee
thanks, that's look the way I'm thinking about. But I'm still hoping for some opinions about pros and cons of the 3 ways
- dynamic visibility
- entity visibility with GC 60
- Attdef visibility with GC 70
Peter
BricsCAD V23
lamarn
« Reply #6 on: April 13, 2015, 04:07:45 PM »
I would like to use ddatte2 to my routine.
This code makes it easy to use a mixed kind of attributes.
But if i replace ddatte with c:ddatte2 i can not make it work.
I would like to get some idea's what i can do. Thanks in advance
Hans
(defun C:ed () (editicc))   ; ...DEFAULT EDIT ROUTINE FOR MIXED TEXT STUFF...
(defun editicc (/ SS CNT NUM SENT ANS oldsnp ent els tx1 sta )
  (command "undo" "group")
  (setq oldsnp (getvar "snapmode"))
  (setvar "snapmode" 0)
  (prompt "\n  Multi-Edit  ")
  (if (>= (getvar "acadver") "13")
    (setq SS (ssget '((-4 . "<or")
      (0 . "RTEXT")
                      (0 . "ATTDEF")
                      (0 . "DIMENSION")
                      (0 . "MTEXT")
                      (0 . "TEXT")
      (0 . "MULTILEADER")
                      (0 . "TOLERANCE")
                      (-4 . "<and")
                      (0 . "INSERT")
                      (66 . 1)
                      (-4 . "and>")
                      (-4 . "or>")
                      (0 . "ATTDEF")
                      (0 . "TEXT")
                      (-4 . "<and")
                      (0 . "INSERT")
                      (66 . 1)
                      (-4 . "and>")
                      (-4 . "or>")
  (if SS
      (setq NUM (sslength SS)
            CNT 0
      (while (< CNT NUM)
        (princ (strcat "\r Edit : "
                       (rtos (1+ CNT) 2 0)
                       " of "
                       (rtos NUM 2 0)
        (setq SENT (ssname SS CNT))
        (setq ANS (cdr (assoc 0 (entget SENT))))
          ((or (eq ANS "ATTDEF")
               (eq ANS "TEXT")
               (eq ANS "TOLERANCE")
       (eq ANS "MULTILEADER")
           (command "textedit" SENT \)
  ((or (eq ANS "MTEXT")
           (command "mtedit" SENT \)
  ((or (eq ANS "rtext")
           (command "rtedit" SENT \ pause)
  ((or (eq ANS "DIMENSION")
           (command "ddedit" SENT \)
          ((eq ANS "INSERT")
           (command "DDatte" SENT \)    ;;; .. THIS LINE IS FOR STANDARD DDATTE WHICH I WOULD LIKE TO MAKE C:DDATT2, BUT HOW...?
  ((eq ANS "RTEXT") (c:RTEDIT))
        (entupd SENT)
        (setq CNT (1+ CNT))
      (princ "  Done... ")
    (princ "  Nothing selected. ")
  (setvar "snapmode" oldsnp)
  (command "undo" "end")
) ;EOF
Peter2
« Reply #7 on: April 13, 2015, 04:40:31 PM »
I would like to use ddatte2 to my routine....
((eq ANS "INSERT")
....) ;EOF
Usually, a lisp is called from a lisp-file like
  1. (c:ddatte2)
- no "command", no quotation mark. But of course there a lisps which need parameter, some have an unexpected reurn-value: you have to check and to try.
Peter
BricsCAD V23
« Reply #8 on: April 13, 2015, 05:19:17 PM »
Without modifying the ddatte2 code, and assuming PICKFIRST is set to 1 (though, this could be set in your code if necessary), try replacing:
With:
(sssetfirst nil (ssadd sent))
(c:ddatte2)
You will also need to ensure the selected block is attributed.
(@Peter2, apologies for derailing the thread!)
owenwengerd
« Reply #9 on: April 13, 2015, 06:00:15 PM »
Sorry, I don't have anything more technical other than to point out that Autodesk very wisely abandoned dynamic blocks for the associative network framework.
lamarn
« Reply #10 on: April 14, 2015, 02:39:25 AM »
Thanks Lee Mac, and sorry for derailling the dynamic block discussion.
Happy Birthday to you!!
(please skip my edit routine from now then)
