Author Topic: RemoveNth ...  (Read 14538 times)
RemoveNth ...
« on: April 23, 2005, 01:08:08 AM »
Having residual caffiene in my system and thinking about Chuck's discussion earlier today on car | cdr I got to thinking about a real old vanilla lisp version of removenth that I had penned using cdr, member etc. and then dreamed up this little number I thought might make Se7en's forehead twitch a bit.
(defun RemoveNth ( n lst / len foo i )
    (defun foo (x)
        (if (eq n (setq i (1+ i)))
            (defun foo (x) nil)
        (   (zerop n) (cdr lst))
        (   (eq n (1- (setq len (length lst))))
            (reverse (cdr (reverse lst)))
        (   (< (setq i -1) n len)
            (vl-remove-if 'foo lst)
        (   lst  )
;;  examples of use
(setq lst '(0 1 2 3 4 5 6 7))
(removenth -1 lst) ;; => (0 1 2 3 4 5 6 7)
(removenth 0 lst)  ;; => (1 2 3 4 5 6 7)
(removenth 4 lst)  ;; => (0 1 2 3 5 6 7)
(removenth 7 lst)  ;; => (0 1 2 3 4 5 6)
(removenth 8 lst)  ;; => (0 1 2 3 4 5 6 7)
What do ya think?
:lol:
(Pssst -- there's room for optimization, can ya see it?)
Edit: Updated to reflect this post, much better.
RemoveNth ...
« Reply #1 on: April 23, 2005, 01:16:13 AM »
heh, I'm pleased It doesn't have comments in it :)
That double defun is tricky
RemoveNth ...
« Reply #2 on: April 23, 2005, 01:22:38 AM »
  • Custom Title
RemoveNth ...
« Reply #3 on: April 23, 2005, 01:24:52 AM »
hehehehe ........ LOL
that's great stuff MP.
RemoveNth ...
« Reply #4 on: April 23, 2005, 01:27:37 AM »
Too much coffee today; seriously. :shock:
Thank you Kerry, thank you Mark.
:lol:
RemoveNth ...
« Reply #5 on: April 23, 2005, 01:28:03 AM »
hehehe .. is that the code monkey ??
is he caffinated too ?
RemoveNth ...
« Reply #6 on: April 23, 2005, 01:30:35 AM »
He's known as <PeterSellersVoice>'the code minkey'</PeterSellersVoice>.
RemoveNth ...
« Reply #7 on: April 23, 2005, 01:34:22 AM »
That is a sick bit of code Michael. What brand of coffee do you have in the drip bag.?
RemoveNth ...
« Reply #8 on: April 23, 2005, 01:35:48 AM »
Instant. Works fast -- no waiting.
:lol:
nivuahc
RemoveNth ...
« Reply #9 on: April 23, 2005, 06:44:52 AM »
<-- sockless
RemoveNth ...
« Reply #10 on: April 23, 2005, 07:17:12 AM »
Do you guys like this variant?
    (defun foo (pair)
            (defun foo (pair) nil)
        (   lst  )
:lol:
nivuahc
RemoveNth ...
« Reply #11 on: April 23, 2005, 07:22:18 AM »
Now you're just being a show-off :P
:dood:
RemoveNth ...
« Reply #12 on: April 23, 2005, 07:25:47 AM »
Actually, it should read like this --
    (defun foo (x)
            (defun foo (x) nil)
        (   lst  )
There is still at least one level of optimization that can be done in my mind. Any takers?
  • Custom Title
RemoveNth ...
« Reply #13 on: April 23, 2005, 07:35:16 AM »
Any takers?
yea right ..... I wish.
I'm still hung-up on ...
(defun foo (x)
            (defun foo (x) nil)
RemoveNth ...
« Reply #14 on: April 23, 2005, 07:40:24 AM »
Want for me to 'splain?
BRB (grabbin' a mug o' brew ...)
