Note 1 -- I need to check for the directory BIND, if it's there, great, continue the code. If not, then make the directory to save the dwg to.
;; # 1 ;; if directory 'bind' does not exist then create (if (not (vl-file-directory-p "c:\\SomePathTo\\Bind")) (vl-mkdir "c:\\SomePathTo\\Bind") )
Note 2 -- I need to check for an existing dwg w/ same name. If it exists, over write. If not, great, continue code.
Mark,Don't you have to do a vl-load or something like that somewhere in the beginning to have the vl- commands work
