Author Topic: How to get entire texstyle info via DBX?  (Read 4775 times)
Peter2
« on: October 27, 2014, 06:05:03 PM »
Hi
in this thread Kerry showed some examples to get drawing info via DBX:
http://www.theswamp.org/index.php?topic=45935.msg510750#msg510750
The code
(defun kdub:listtextstyles ()
    (kdub:listcollmbrnames (vla-get-textstyles kglobal:activedoc))
returns the names of the existing textstyles ("Standard", "Bold", "Thin",..), but I need the used fonts (isocp.shx, simplex.shx, arial.ttf) too.
Any ideas how to get them?
Peter
Peter
BricsCAD V23
Re: How to get entire texstyle info via DBX?
« Reply #1 on: October 27, 2014, 06:26:37 PM »
Here's a quick example:
  1. (defun textstylefonts ( doc / rtn )
  2.     (vlax-for sty (vla-get-textstyles doc)
  3.         (setq rtn (cons (cons (vla-get-name sty) (vla-get-fontfile sty)) rtn))
  4.     )
  5.     (reverse rtn)
  6. )
Call with the Document object you wish to query:
You can use vlax-dump-object with a Textstyle object to view all available properties & methods.
« Last Edit: October 27, 2014, 06:30:41 PM by Lee Mac »
Peter2
« Reply #2 on: October 27, 2014, 06:38:49 PM »
Hi Lee
thanks a lot.
In the meantime I found a similar solution from the year 2006:
http://www.theswamp.org/index.php?topic=8587.msg109725#msg109725
Regards
Peter
Peter
BricsCAD V23
« Reply #3 on: October 27, 2014, 07:26:47 PM »
Quick and dirty start point:
(defun _GetTextStyles ( doc dxf_flag / @Try @GetStylePropsAX @GetStylePropsDXF @Main )
    (defun @Try ( try_statement / try_result )
        (vl-catch-all-apply
            (function
                (lambda ( )
                    (setq try_result (eval try_statement))
        try_result
    (defun @GetStylePropsAX ( style )
        (mapcar
            (function (lambda (p) (cons p (@Try '(vlax-get style p)))))
           '(   Name
                BigFontFile
                FontFile
                Height
                LastHeight
                ObliqueAngle
                TextGenerationFlag
                Width
    (defun @GetStylePropsDXF ( style )
        (@Try
           '(vl-remove-if
                (function
                    (lambda ( p / key )
                        (or
                            (minusp (setq key (car p)))
                            (< 70 key)
                            (member key '(5))
                (entget
                    (vlax-vla-object->ename style)
    (defun @Main ( doc dxf_flag / func result )
        (setq func (if dxf_flag @GetStylePropsDXF @GetStylePropsAX))
        (@Try
           '(vlax-for style (vla-get-textstyles doc)
                (setq result
                    (cons
                        (func style)
                        result
        (reverse result)
    (@Main doc dxf_flag)
Result (_GetTextStyles doc nil):
        (NAME . "STANDARD")
        (BIGFONTFILE . "")
        (FONTFILE . "txt")
        (HEIGHT . 0.0)
        (LASTHEIGHT . 0.2)
        (OBLIQUEANGLE . 0.0)
        (TEXTGENERATIONFLAG . 0)
        (WIDTH . 1.0)
        (NAME . "SOME_MODEL|Standard")
        (BIGFONTFILE . "")
        (FONTFILE . "romans.shx")
        (HEIGHT . 0.0)
        (LASTHEIGHT . 2.5)
        (WIDTH . 1.0)
Result (_GetTextStyles doc T):
        (0 . "STYLE")
        (2 . "STANDARD")
        (70 . 0)
        (40 . 0.0)
        (41 . 1.0)
        (50 . 0.0)
        (42 . 0.2)
        (3 . "txt")
        (4 . "")
        (0 . "STYLE")
        (2 . "SOME_MODEL|Standard")
        (70 . 48)
        (40 . 0.0)
        (41 . 1.0)
        (50 . 0.0)
        (42 . 2.5)
        (3 . "romans.shx")
        (4 . "")
« Last Edit: October 27, 2014, 07:35:51 PM by MP »
« Reply #4 on: October 27, 2014, 07:46:55 PM »
Great to see you posting code again MP :-)
Peter2
« Reply #5 on: October 27, 2014, 07:57:54 PM »
Thanks to MP too.
This posting will go to my archive.
Peter
Peter
BricsCAD V23
« Reply #6 on: October 27, 2014, 09:01:45 PM »
Thanks for the kind feedback guys. Wish I had time for more than the occasional 5 minute quick and dirty post. The good news is I'm so busy time is flying at break neck speed -- can't believe I've been with my employer over a year already -- feels like I started here just a couple months ago. :wack:
alanjt
  • Standby for witty remark...
« Reply #7 on: October 28, 2014, 05:51:47 PM »
I swear, looking at MP's code is like walking through a fine art gallery.
Dropbox
« Reply #8 on: October 28, 2014, 05:57:48 PM »
True, but it's a bit more functional than an old Rubins.
alanjt
« Reply #9 on: October 28, 2014, 06:01:25 PM »
More like....
http://www.angelfire.com/hiphop/diablo4u/remedios.html
 :-P
Dropbox
« Reply #10 on: October 28, 2014, 06:49:26 PM »
lol, in before macabre Hieronymus Bosch references :-D
Peter2
« Reply #11 on: October 29, 2014, 07:15:12 PM »
(defun @GetStylePropsAX ( style ) ...
Do I understand it right that the ActiveX-method does not return the group-code 70 (Shape, vertical, external, ..)?
Peter
Peter
BricsCAD V23
« Reply #12 on: October 29, 2014, 07:26:54 PM »
Bit flag states encoded in the 70 dxf group find residence in the TextGenerationFlag property.
Peter2
« Reply #13 on: October 29, 2014, 07:30:34 PM »
OK, thanks  :-)
Peter
Peter
BricsCAD V23
« Reply #14 on: October 29, 2014, 07:47:24 PM »
You're most welcome Peter.
