Author Topic: if statement question  (Read 2395 times)
andrew_nao
« on: August 05, 2014, 03:12:30 PM »
whats the best way to approach if statements.
basically im wanting match var 1 to either var 2, 3 or 4 and if var 1 is does not match var 2, 3 or 4 then do my thing.
thnks
kpblc
Re: if statement question
« Reply #1 on: August 05, 2014, 03:26:33 PM »
I didn't test the speed. For example:
(defun test (/ var1 var2 var3 var4)
  (setq var1 12
var2 13
var3 15
var3 123
  ;; variant 1
  (if (not (member var1 (list var2 var3 var4)))
      ;; do what you want
  ;; variant 2
  (if (not (apply (function or)
  (mapcar
    (function
      (LAMBDA (x)
(equal var1 x 1e-3)
      ;; do what you want
Sorry for my English.
« Reply #2 on: August 05, 2014, 03:36:12 PM »
Couple more:
  (if (vl-some '(lambda (x) (equal var1 x)) (list var2 var3 var4))
      ;; Exit
      ;; do what you want
  (if (vl-position var1 (list var2 var3 var4))
      ;; Exit
      ;; do what you want
« Reply #3 on: August 05, 2014, 05:21:16 PM »
Another:
(if (or (equal var1 var2)
        (equal var1 var3)
        (equal var1 var4)
    ;; do what you want
« Reply #4 on: August 06, 2014, 07:42:11 AM »
andrew_nao
« Reply #5 on: August 06, 2014, 03:01:25 PM »
For Andrew
http://www.theswamp.org/index.php?topic=13046.msg158557#msg158557
excellent post CAB,
thanks for this
and thank you everyone for your help
snownut2
  • Bricscad 22 Ultimate
« Reply #6 on: August 08, 2014, 08:32:59 AM »
      ;; Exit
      ;; do what you want
Good one ronjonp......
« Reply #7 on: August 08, 2014, 08:42:22 AM »
      ;; Exit
      ;; do what you want
