Author Topic: SHX-text as Text to PDF?  (Read 13646 times)
Peter2
« on: July 01, 2014, 07:13:47 AM »
Hi
usually, SHX-strings are converted to "Lines which looks like a string" while creating a PDF.
Are there solutions / apps which can create searchable text in PDF, based on SHX?
Thanks and regards
Peter
BricsCAD V23
irneb
Re: SHX-text as Text to PDF?
« Reply #1 on: July 01, 2014, 08:40:12 AM »
Nope, though you can change the font to a TTF font instead before you plot/save the PDF.
Peter2
« Reply #2 on: July 01, 2014, 08:51:53 AM »
Thanks. The answer leads to the next question:
Who knows / has experience with a "SHX to TTF converter"??  :?
Peter
BricsCAD V23
irneb
« Reply #3 on: July 01, 2014, 09:07:51 AM »
You don't need a converter. You change the style's font in AutoCAD's style dialog - just type style at the command-line.
If you want similar appearance, then AutoDesk's already added most of the standard SHX fonts as TTF fonts. These are actually used to display in the MText editor. Unfortunately you can't directly use them as is in ACad. You'd need to make new copies of them and then rename the files before you can set the style to those fonts in acad.
If you've got special SHX fonts and want to turn them into TTF's. I'm sorry but that's rather difficult - the 2 font definition types aren't compatible. A SHX is like a description of how to move a pen to make each character, while a TTF is like a description of the borders around a filled in space for each character.
Peter2
« Reply #4 on: July 01, 2014, 09:26:16 AM »
...If you've got special SHX fonts and want to turn them into TTF's. I'm sorry but that's rather difficult - the 2 font definition types aren't compatible....
This is why I asked (but to be honest, with not much hope  :cry: )
Thanks irneb, maybe another user has an advice (but I'm realistic ....)
Peter
BricsCAD V23
« Reply #5 on: July 01, 2014, 02:33:23 PM »
Can't be that difficult to create a TTF file.
http://www.ehow.com/how_6956130_create-ttf.html
« Reply #6 on: July 01, 2014, 02:35:30 PM »
ROBBO
« Reply #7 on: July 01, 2014, 04:39:34 PM »
Perhaps mapping your shx font to a ttf would solve this. Haven't tried this, but perhaps adding a line in your acad.fmp: e.g. romans.shx; romans__.ttf
might work.
« Last Edit: July 01, 2014, 05:13:37 PM by ROBBO »
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Peter2
« Reply #8 on: July 01, 2014, 04:44:14 PM »
Thanks to both of you.
@CAB:
I will save the links for later use.
@ROBBO:
Yes, mapping could / should work - if there exists a corresponding TTF.
Peter
BricsCAD V23
ROBBO
« Reply #9 on: July 01, 2014, 04:55:37 PM »
A ttf font should exist as the mtext editor uses these to display the the text styles, I believe.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Some-TrueType-fonts-not-listed.html
« Last Edit: July 01, 2014, 05:27:53 PM by ROBBO »
Oscar Wilde
cmwade77
« Reply #10 on: July 02, 2014, 11:38:53 AM »
Just be aware that if you xref a file with a lot of TTF text, the resulting drawing will become EXTREMELY slow to open. We have had some take as much as an hour to open due to the number of xrefs that had TTF fonts in them, we changed them to SHX in all of the xRefs and the same file opened in under a minute.
Here is the thread that I had asking about changing TTF fonts to SHX fonts through LISP:
http://www.theswamp.org/index.php?topic=47156.0
If you want the text to be searchable though, you can use Bluebeam Extreme as your PDF reader and use the OCR feature, I find that it is extremely accurate and very fast. You can find more details about it at: http://bluebeam.com/us/products/revu/extreme.asp
This would avoid the TTF performance hit in your drawings at least.
I would also think that you could use a reactor and modify the LISP routine above to automatically change SHX styles to TTF before potting, them change them back once the plot is done and this may also help avoid the performance hit as far ans opening and closing the drawings go. Although plotting drawings with a lot of TTF text in them also has a similar performance hit, especially within xRefs.
« Last Edit: July 02, 2014, 11:48:00 AM by cmwade77 »
Peter2
« Reply #11 on: July 02, 2014, 12:39:06 PM »
Just be aware that if you xref a file with a lot of TTF text, the resulting drawing will become EXTREMELY slow to open. We have had some take as much as an hour to open due to the number of xrefs that had TTF fonts in them, we changed them to SHX in all of the xRefs and the same file opened in under a minute. ....
That's good to know (again). I made this experience 15 years ago (Acad 14, 2000), but since this time I did not use such big files again. In the meantime I thought this issue is solved - better integration in OS, high-speed machines and so on.
So I'm surprised the issue still exists.
...Here is the thread that I had asking about changing TTF fonts to SHX fonts through LISP:...
Yes, I think my next steps will investigate in the results above: mapping, font changing, ...
...If you want the text to be searchable though, you can use Bluebeam Extreme as your PDF reader and use the OCR feature, I find that it is extremely accurate and very fast. You can find more details about it at: http://bluebeam.com/us/products/revu/extreme.asp ...
I made only quick tests with OCR inside the "PDFXChange-Viewer". I saw that it works fine on newspapers and old typewriter-text, but with new created PDFs using ISOCP.shx it has problems to distinguish "1 l t  f I ..."
But I'm aware that OCR is a science and not "click to button - done" solution.
Peter
Peter
BricsCAD V23
dgorsman
« Reply #12 on: July 02, 2014, 06:31:37 PM »
I'm not noticing this...  Maybe you could define "lot of TTF text"   :?
Is it possible it was applying font mapping or alternate font substitution for TTF fonts not installed?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
danallen
« Reply #13 on: July 02, 2014, 06:53:39 PM »
I just did a test of lots of TTF text xreffed into a file, image attached. No change in drawing open. My guess is that many texts say on a site plan with rotations, scales, etc, might affect plotting and regens, but not drawing opens.
Dan
cmwade77
« Reply #14 on: July 02, 2014, 07:25:21 PM »
Peter
We used to use PDF xChange Viewer, but we ran into similar issues, Bluebeam Extreme, while slightly more expensive does an excellent job with OCR on CAD drawings in my experience. There is a free trial to test it.
