Author Topic: Making layers by lisp  (Read 6010 times)
Fabricio28
« on: May 20, 2014, 09:32:00 AM »
Hi guys,
I'm trying the make layers. That code isn't working properly.
Can anybody help me out, please?
(defun c:mkl()
  (makelayer)
    (setq layername     "-AUXILIAR"
          colornum      4
          linetype      "CONTINUOUS"
   (makelayer)
   (setq layername     "-CERCA"
          colornum      5
          linetype      "CERCA"
    (makelayer)
    (setq layername     "-CN-MM"
          colornum     251
    (makelayer)
    (setq layername     "-CN-5-5M"
          colornum      30
   (makelayer)
   (setq layername     "-CONFRONTANTES"
          colornum      1
   (makelayer)
    (setq layername     "-CONSTRUÇÕES"
          colornum      140
  (makelayer)
  (setq layername     "-COTAS"
          colornum      5
  (makelayer)
  (setq layername     "-DETALHES"
          colornum      5
  (makelayer)
    (setq layername     "-MARGEM"
          colornum      7
  (makelayer)
  (setq layername     "-MEDIDAS"
          colornum      4
  (makelayer)
  (setq layername     "-NRO-DIVISA"
          colornum      2
    (makelayer)
    (setq layername     "-PASSEIO"
          colornum      3
          linetype      "PHANTOM"
  (makelayer)
    (setq layername     "-TERRENO"
          colornum      180
  (makelayer)
    (setq layername     "LIXO"
          colornum      7
); mkl
(defun makelayer()
    (command "layer"
             "m"
             layername
             "c"
             colornum
             layername
             "lt"
             linetype
             layername
             "s"
              "0"
(princ "\nStandard Layers Created...\n")
(mkl)
Thank in advance
tedg
Re: Making layers by lisp
« Reply #1 on: May 20, 2014, 09:54:38 AM »
What is not working? I didn't try your code but your screen shot appears to have the layers the way you intend?
The VLisp stuff is a bit over my head, I dabble with Autolisp to create layers, I just haven't made that leap yet.
(setq la (getvar "clayer"))
 (SETQ LR1 (TBLSEARCH "LAYER" "S-DETL-0035"))
 (SETQ LR2 (TBLSEARCH "LAYER" "S-ANNO-NPLT"))
 (SETQ LR3 (TBLSEARCH "LAYER" "S-DETL-CNTR"))
  (IF (= LR1 NIL)
  (command "layer" "make" "S-DETL-0035" "color" "3" "" "lw" "0.35" "" ""))
  (IF (= LR2 NIL)
  (command "layer" "make" "S-ANNO-NPLT" "COLOR" "140" "" "PLOT" "N" "" "lw" "0.18" "" ""))
  (IF (= LR3 NIL)
  (command "layer" "make" "S-DETL-CNTR" "COLOR" "1" "" "lw" "0.18" "" "LT" "CENTER2" "" ""))
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Fabricio28
« Reply #2 on: May 20, 2014, 09:58:29 AM »
Hi tedg,
Thank you for the quick replay.
The image attached is the exactly I want to, it is just an exemple of my request.
Could you help me out with my code?
« Reply #3 on: May 20, 2014, 10:09:15 AM »
Most likely your trying to push a linetype to a layer that does not exist in the drawing. FWIW  .. here's how I'd restructure your code.
You also might want to get away from the command call to create the layer (or just use a template). There are numerous examples here to create layers using entmakex. Clickety
(defun c:mkl (/ makelayer)
  (defun layermake (lyrname color ltype)
    (if   (tblsearch "LAYER" lyrname)
      (command "._Layer" "_Thaw" lyrname "_On" lyrname "_UnLock" lyrname "_Set" lyrname "")
      (command "._Layer"
          "_Make"
          lyrname
          "_Color"
          (if (or (null color) (= color ""))
       "_White"
       color
          lyrname
          "LT"
          (if (or (null ltype) (= ltype ""))
       "Continuous"
       ltype
          lyrname
  (foreach x '(("-AUXILIAR" 4 "CONTINUOUS")
          ("-CERCA" 5 "CERCA")
          ("-CN-MM" 251 "CONTINUOUS")
          ("-CN-5-5M" 30 "CONTINUOUS")
          ("-CONFRONTANTES" 1 "CONTINUOUS")
          ("-CONSTRUÇÕES" 140 "CONTINUOUS")
          ("-COTAS" 5 "CONTINUOUS")
          ("-DETALHES" 5 "CONTINUOUS")
          ("-MARGEM" 7 "CONTINUOUS")
          ("-MEDIDAS" 4 "CONTINUOUS")
          ("-NRO-DIVISA" 2 "CONTINUOUS")
          ("-PASSEIO" 3 "PHANTOM")
          ("-TERRENO" 180 "CONTINUOUS")
          ("LIXO" 7 "CONTINUOUS")
    (layermake (car x) (cadr x) (caddr x))
« Last Edit: May 20, 2014, 10:41:54 AM by ronjonp »
« Reply #4 on: May 20, 2014, 10:13:37 AM »
Here is my simple layer creator:
  1. (defun LayerMake(lyrname Color ltype)
  2.   (if (tblsearch "LAYER" lyrname)
  3.     (command "._Layer" "_Thaw" lyrname "_On" lyrname "_UnLock" lyrname "_Set" lyrname "")
  4.     (command "._Layer" "_Make" lyrname "_Color"
  5.              (if (or (null color)(= Color "")) "_White" Color) lyrname
  6.              "LT" (if (or (null ltype)(= ltype "")) "Continuous" ltype) lyrname "")
  7.   )
  8. )
Fabricio28
« Reply #5 on: May 20, 2014, 10:20:55 AM »
your code just create AUXILIAR layer. Am I doing something wrong?
I don't know how Can I create layers using your code.
Coul you help me, please?
regards
« Reply #6 on: May 20, 2014, 10:35:37 AM »
regards
FABRICIO28,
I did not test your makelayer function, just provided a different way to organize the code. Use CAB's 'LayerMake' function instead of yours.
*code updated above to use Charles function.
« Last Edit: May 20, 2014, 10:41:26 AM by ronjonp »
snownut2
  • Bricscad 22 Ultimate
« Reply #7 on: May 20, 2014, 10:55:29 AM »
Looks to me like you need to move the (makelayer) call to after the setq's not before as shown, then all should work fine.
snownut2
« Reply #8 on: May 20, 2014, 11:02:56 AM »
Although to simplify it a bit you might do this;
  1. (foreach x '(("-AUXILIAR"  4  "CONTINUOUS")
  2.              ("-CERCA"  5  "CERCA")
  3.    )
  4.    (setq layername (car x)
  5.          colornum  (cadr x)
  6.          linetype  (caddr x))
  7.     (makelayer)
  8.  )
  9.
« Last Edit: May 20, 2014, 11:09:00 AM by snownut2 »
« Reply #9 on: May 20, 2014, 11:03:01 AM »
Something like this
  7.      )
  8.     )
  9.
  10. (layerMake  "-AUXILIAR"       4  "CONTINUOUS"      )
  11. (layerMake  "-CERCA"   5   "CERCA"                 )
  12. (layerMake  "-CN-MM"  251   "CONTINUOUS"           )
  13. (layerMake  "-CN-5-5M"   30   "CONTINUOUS"         )
  14. (layerMake  "-CONFRONTANTES"   1   "CONTINUOUS"    )
  15. (layerMake  "-CONSTRUÇÕES"   140   "CONTINUOUS"    )
  16. (layerMake  "-COTAS"   5   "CONTINUOUS"            )
  17. (layerMake  "-DETALHES"   5   "CONTINUOUS"         )
  18. (layerMake  "-MARGEM"  7  "CONTINUOUS"             )
  19. (layerMake  "-MEDIDAS"  4  "CONTINUOUS"            )
  20. (layerMake  "-NRO-DIVISA"  2  "CONTINUOUS"         )
  21. (layerMake  "-PASSEIO"  3  "PHANTOM"               )
  22. (layerMake  "-TERRENO"  180  "CONTINUOUS"          )
  23. (layerMake  "LIXO"  7  "CONTINUOUS"                )
Fabricio28
« Reply #10 on: May 20, 2014, 11:16:36 AM »
wonderful job CAB!
Thank you very much.  :-D
Thank you all of you guys!!
GDF
« Reply #11 on: May 20, 2014, 11:23:07 AM »
or you could use:
vla-Put-TrueColor
vla-Put-Linetype
vla-Put-Lineweight
vla-Put-Description
« Reply #12 on: May 20, 2014, 05:30:06 PM »
This post may also be helpful.
