Author Topic: little help with pointsin.lsp  (Read 4591 times)
Re: little help with pointsin.lsp
« Reply #15 on: March 07, 2014, 06:08:55 PM »
In your modified code you are calling PI:INSERTPOINTBLOCK, passing value SCL1
SCL1 is defined after you call  PI:INSERTPOINTBLOCK ; it should be defined before, otherwise wou will pass nil as a parameter value.
No wait,
SCL1 is a global variable defined after you are using it.
« Last Edit: March 07, 2014, 06:17:47 PM by Kerry »
pedroantonio
« Reply #16 on: March 08, 2014, 11:00:25 AM »
i am confused !!! :embarrassed:
« Reply #17 on: March 08, 2014, 11:14:12 AM »
You woke me up at 2:00 am on Sunday morning to tell me that ??
« Reply #18 on: March 08, 2014, 11:17:35 AM »
<blink> What the ... When did you guys become an item?
