Author Topic: Color for "grdraw"  (Read 2298 times)
Peter2
Color for "grdraw"
« on: February 07, 2014, 11:15:52 AM »
Hi
I have this simple code,
(setq startpunkt (getpoint "\nClick startpoint: ")
      endpunkt (getpoint startpunkt "\nClick endpoint: "))
where I create a "rubber band line" (sorry, I don't know the correct English word) between startpoint and cursor.
How can I set the color (and the lineweight??) of this line?
Peter
BricsCAD V23
Re: Color for "grdraw"
« Reply #1 on: February 07, 2014, 11:36:18 AM »
Here's for color:
(and (setq startpunkt (getpoint "\nClick startpoint: "))
     (setq endpunkt (getpoint startpunkt "\nClick endpoint: "))
     ;; start end color
     (grdraw startpunkt endpunkt 5)
Peter2
« Reply #2 on: February 07, 2014, 03:43:41 PM »
Hi ronjonp
thanks, but you misunderstood (or I described it wrong ..). I don't need a grdraw after clicking the endpoint, I need it before clicking the endpoint (as grdraw or as modification of the getpoint line).
Peter
BricsCAD V23
« Reply #3 on: February 07, 2014, 04:09:50 PM »
Here is a quick example:
(defun c:foo (/ p p1 p2)
  (if (setq p1 (getpoint "\nPick a point: "))
    (while (and (setq p2 (grread 5)) (= (car p2) 5)) (redraw) (grdraw p1 (setq p2 (cadr p2)) 1))
  (list p1 p2)
And here are a few examples of GRREAD
http://www.theswamp.org/index.php?topic=12813.msg156555#msg156555
« Last Edit: February 07, 2014, 04:13:26 PM by ronjonp »
Peter2
« Reply #4 on: February 07, 2014, 04:12:48 PM »
Thanks. Now I see that there must be a full grdraw-function and no modification of getpoint.
Peter
BricsCAD V23
« Reply #5 on: February 08, 2014, 07:08:54 AM »
This is pretty much the only modification of the rubber-band you can make with getpoint:
(defun c:test ( / p )
    (if (setq p (getpoint "\nStart: "))
            (initget 32)
            (getpoint p "\nEnd: ")
Otherwise, a grread/grdraw/grvecs combination must be used (as Ron has demonstrated), however, the use of grread sacrifices all standard drawing aids (such as Object Snap / Orthomode / Tracking etc).
Peter2
« Reply #6 on: February 10, 2014, 09:46:47 AM »
Thanks to all
I'm on my way now.
Peter
BricsCAD V23
