Author Topic: Data Shortcuts - Surfaces  (Read 3034 times)
kevinh
« on: December 19, 2013, 04:47:17 PM »
I have a project where I have two different topo drawings by two surveyors in two different offices.  I want to keep the topo drawings separated but combine them in the design drawing so that I only have to target one surface, ect.
Is there a way to data shortcut them into the design drawing and combine the two existing surfaces at the same time??
BlackBox
Re: Data Shortcuts - Surfaces
« Reply #1 on: December 19, 2013, 06:29:38 PM »
Not that I am aware of; you're better off using LandXML to export each surface, then in your design drawing import the LandXML surfaces, combine them into a single, new surface, and remove any residual.
HTH
« Reply #2 on: December 19, 2013, 08:34:37 PM »
I would think you could add data refs for each one then paste them both into a surface for use as desired.
« Reply #3 on: February 26, 2014, 11:51:22 AM »
What Jeff said, only Datashort cut the two surfaces in.
Then create an Empty surface, and paste those other two into it.
alanjt
  • Standby for witty remark...
« Reply #4 on: February 26, 2014, 12:01:10 PM »
x2
Here's a procedure question, when updating an existing surface, would you recommend just adding the new points to the surface and regenerating it, or leaving it as is, and generating a surface of the new area, then pasting everything together?
Dropbox
« Reply #5 on: February 26, 2014, 12:10:51 PM »
x2
I think that would depend.
Is this a small amendment to the data, the addition of supplemental information?
If YES
Then, I would copy the original surface, and add the new information to it, and update the description.
So that one knows as of which date the surface is current.
The Original surface EG1 should then be set to a NO DISPLAY Style, and have the name changed to
EG 1 (Archive) or EG1 (obsolete)
So that others know it is Not the Surface they are looking for.
If however it is of the nature of ADDING proposed Phase 1 information the the Existing model such that Phase Two
can be designed to Match
Then
Export EG to XML
Rename EG and update description as above
Remove Triangles from the Area where the Phase 1 information lies
Paste in Phase 1 Data
The Triangle removal is to prevent the paste operation from A) failing, or B) sometimes there is conflicting information
that 'leaks' through and prevents the paste operation from being 100%.
Should you need the original data, now reimport the file you sent out with XML
Otherwise it remains as achieve in the project folder.
Dave M
« Reply #6 on: February 26, 2014, 12:25:44 PM »
Create a new, empty surface in the design drawing.  Data shortcut in the other surfaces and set their style to a no display style.  Then you can paste the two surfaces into the empty surface.
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
