Author Topic: Set page-size of Windows-printers via Autolisp  (Read 4412 times)
Peter2
« on: November 08, 2013, 06:17:24 PM »
I'm playing around with flexible, automated page-sizes which should be configured by Autolisp. One of my ideas (not solutions ...) is
- to add a special paper-size via "Windows - Printers - Print server propeerties - Forms" (sorry, if not correctly re-translated from German) and
- to modify the paper-size via Autolisp (vl-registry-write ...)
Now I have a registry-entry like this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Forms\PDF_Formatter]
"FormKeyword"=hex:7b,35,44,42,42,30,42,43,43,2d,43,43,46,41,2d,34,37,42,45,2d,\
  41,34,46,41,2d,45,41,35,44,32,39,41,46,36,33,32,32,7d,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Forms]
"PDF_Formatter"=hex:d0,bf,0b,00,80,6d,0d,00,00,00,00,00,00,00,00,00,d0,bf,0b,\
  00,80,6d,0d,00,4c,00,00,00,00,00,00,00
Now the questions are:
a) Is the basic idea realisable? If yes - how to handle the registry?
b) Or are there better solutions?
Thanks and regards
Peter
BricsCAD V23
kruuger
Re: Set page-size of Windows-printers via Autolisp
« Reply #1 on: January 08, 2015, 04:12:36 PM »
hi Peter
any luck with this ?
did anyone was able to add custom paper sizes via lisp ?
digging google all day but nothing  :(
thx
kruuger
Peter2
« Reply #2 on: January 09, 2015, 03:25:34 AM »
hi Peter
any luck with this ?...
Hi kruuger
no success  :-(. I hoped to find a common way for all printers, but at least I found a special printer device with separate paper settings in the registry.
But no solution for the original question.
Peter
BricsCAD V23
kruuger
« Reply #3 on: January 09, 2015, 03:47:38 AM »
hi Peter
Hi kruuger
no success  :( . I hoped to find a common way for all printers, but at least I found a special printer device with separate paper settings in the registry.
:( thanks for info Peter
kruuger
Didge
« Reply #4 on: January 09, 2015, 06:42:08 AM »
Hi Guys,
Although not a direct answer to defining page sizes through lisp, this option may offer a work-around.
I use a standard template file containing all my regular page setups for a multitude of different plotters, printers & PDF's etc.  This coding will then import a specified page setup from that template.
You will need to edit the "template" variable to point towards your own DWT file.
Hope that helps.
Didge.
; (SET-PAGE-SETUP "A3 PDF")
(defun SET-PAGE-SETUP (name / Get-Active-Doc Get-Setups PutPageSetup template f oldfiledia)
  (defun Get-Active-Doc (/) (vla-get-activedocument (vlax-get-acad-object)))
  (defun Get-Setups (/ ret)
    (vl-catch-all-apply '(lambda () (vla-RefreshPlotDeviceInfo (vla-get-Layout (vla-get-PaperSpace (Get-Active-Doc))))))
    (vlax-for x (vla-get-Plotconfigurations (Get-Active-Doc)) (if (= (vla-get-ModelType x) :vlax-false) (setq ret (cons (vla-get-name x) ret))))
    (if ret (setq ret (cons '"Current" (vl-sort ret '<))))
    (cond (ret) ('("Current")))
  (defun PutPageSetup (layout setup / item-p)
    (defun item-p (collection item /)
      (if (not (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (setq item (vla-item collection item)))))) item)
    (and (setq layout (item-p (vla-get-layouts (Get-Active-Doc)) layout))
         (setq setup (item-p (vla-get-plotconfigurations (Get-Active-Doc)) setup))
         (not (vla-copyfrom layout setup))
  (setq template "C:\\TEMP\\STANDARD-PAGE-SETUPS.DWT")
  (if (not (vl-position (strcase name) (mapcar 'strcase (Get-Setups))))
    (if (setq f (findfile template))
        (setq oldfiledia (getvar "filedia"))(setvar "filedia" 0)
        (vl-cmdf "-psetupin" f name)
        (setvar "filedia" oldfiledia)
      (alert (strcat "Unable to locate template file: \n\n" template))
  (if (vl-position (strcase name) (mapcar 'strcase (Get-Setups))) (putpagesetup (getvar "ctab") name))
  (vl-cmdf "RegenAll")
Think Slow......
kruuger
« Reply #5 on: January 09, 2015, 06:52:08 AM »
yes. that is workaround. probably will use it.
thanks Didge
kruuger
HasanCAD
« Reply #6 on: January 12, 2015, 04:50:42 AM »
Thanks Didge
blasto
  • Mosquito
« Reply #7 on: July 07, 2015, 04:30:23 AM »
Hi Didge,
if possible can you send your dwt file?
thanks
