Author Topic: Browse Button Not Working  (Read 2568 times)
dubb
« on: November 07, 2013, 01:44:15 PM »
Weird problem today. My co-worker's [browse] button from the insert dialogue menu is not working.
CMDDIA = 1
FILEDIA = 1
What happened?
jvillarreal
Re: Browse Button Not Working
« Reply #1 on: November 07, 2013, 02:43:02 PM »
You mean after running the "insert" command, the initial dialog shows up but clicking the browse button does nothing?
What version of AutoCAD are you using?
rkmcswain
« Reply #2 on: November 07, 2013, 02:51:52 PM »
After you press "Browse" (and nothing happens), can you click the Cancel button in the Insert dialog --or-- do you have to press ESC first??
jvillarreal
« Reply #3 on: November 07, 2013, 02:54:06 PM »
Seems like a dual monitor issue.
dubb
« Reply #4 on: November 07, 2013, 03:05:56 PM »
Yeah seems like a dual monitor issue. but he is not running dual monitors. To clarify. The insert dialogue box shows up. But when I click on browse, nothing happens. I have to hit Esc first in order to hit cancel. I tried changing resolutions. Could it be that the dialogue box is moved so far out that I cannot see it?
jvillarreal
« Reply #5 on: November 07, 2013, 03:17:19 PM »
Possibly. Have you tried the Alt, spacebar, M, arrow solution?
I would also try "restore down" on the AutoCAD window to ensure its not showing up behind the AutoCAD window.
« Last Edit: November 07, 2013, 03:25:58 PM by jvillarreal »
rkmcswain
« Reply #6 on: November 07, 2013, 03:20:56 PM »
That is exactly what it is.
Here is a quick animation showing your how to get it back. Click on it for a larger version
http://bit.ly/18vS3bZ
dubb
« Reply #7 on: November 07, 2013, 06:59:23 PM »
I fixed. use the [Windows] Button + [Left or Right] to reposition the window.
dubb
« Reply #8 on: November 07, 2013, 07:00:17 PM »
Thank you everybody.  :-P
