Author Topic: eDwgObjectImproperlyRead when reading PlotSettings from a Template  (Read 6402 times)
mjrenaud
« on: September 26, 2013, 02:36:31 PM »
I'm really hoping someone has an idea of what I'm doing wrong here.
I'm reading a template for it's PlotSetttings, to display the properties of any of these PlotSettings in a WindowsForm. The reading of the dictionary value works fine. I can retrieve each PlotSetting's name, but opening that dictionary value to read causes the eDwgObjectImproperlyRead error. Here is the pertinent code that I'm working with:
            using (Transaction acTrans = db.TransactionManager.StartTransaction())
                DBDictionary plSettings = acTrans.GetObject(db.PlotSettingsDictionaryId,
                                                            OpenMode.ForRead) as DBDictionary;
                if (plSettings != null)
                    ListViewItem row;
                    // List each named page setup
                    foreach (DBDictionaryEntry item in plSettings)
                        plotSetting = item.Key;
                        PlotSettings settings = null;
                        settings = acTrans.GetObject(item.Value, OpenMode.ForRead) as PlotSettings;
    This last GetObject() call causes the error... I've hunted all over for all samples I could find that do anything similar, and this is basically the same as those samples. Of course, I don't know for certain that ANY of those sample actually work.
    Any ideas?
It's Alive!
  • Retired
  • AKA Daniel
Re: eDwgObjectImproperlyRead when reading PlotSettings from a Template
« Reply #1 on: September 26, 2013, 08:13:32 PM »
drawing may be bad, try doing an audit
mjrenaud
« Reply #2 on: September 27, 2013, 12:37:40 PM »
Thanks for the suggestion, but the template file appears to be fine.
I suppose the fact that I can open the PlotSettingsDictionary and see the name of each PlotSetting, should have told me that. It's only when I try to open a PlotSetting in that dictionary that I get the error message.
« Last Edit: September 27, 2013, 12:42:04 PM by mjrenaud »
MexicanCustard
« Reply #3 on: September 27, 2013, 02:09:00 PM »
Are you checking the PlotSetting ObjectId to make sure its actually pointing at something before trying to open it?
  item.Value.IsValid
mjrenaud
« Reply #4 on: September 27, 2013, 02:29:48 PM »
I just added that (thanks for the suggestion), but it made no difference.
Jeff H
« Reply #5 on: September 27, 2013, 03:08:54 PM »
Load a file up with plotsettings and someone could inspect it and maybe figure it out.
mjrenaud
« Reply #6 on: September 27, 2013, 03:21:39 PM »
Here is one of the templates that I'm using.
WILL HATCH
« Reply #7 on: September 27, 2013, 08:37:28 PM »
Took a moment to play with this, wrote some code and it works fine with your drawing file... vanilla autocad 2013
Code - C#: [Select]
  1.         [CommandMethod("TestPlotSettings")]
  2.         public void listPlotSettings()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Editor ed = doc.Editor;
  6.             Database db = doc.Database;
  7.             using (Transaction tr = doc.TransactionManager.StartTransaction())
  8.             {
  9.                 DBDictionary Settings = (DBDictionary)tr.GetObject(db.PlotSettingsDictionaryId, OpenMode.ForRead);
  10.                 foreach (DBDictionaryEntry PlotSetting in Settings)
  11.                 {
  12.                     try
  13.                     {
  14.                         ed.WriteMessage("\nPlot Style: {0}", PlotSetting.Key);
  15.                         PlotSettings ps = (PlotSettings)tr.GetObject(PlotSetting.Value, OpenMode.ForRead);
  16.                         ed.WriteMessage("\nDevice Name: {0}", ps.CanonicalMediaName);
  17.                     }
  18.                     catch (System.Exception e)
  19.                     {
  20.                         ed.WriteMessage("\n{0}", e.ToString());
  21.                     }
  22.                 }
  23.             }
  24.         }
Plot Style: Hp1055  (50%Di)
Device Name: User1637
Plot Style: Hp1055  (Ai)
Device Name: User612
Plot Style: Hp1055  (Bi)
Plot Style: Hp1055  (Di)
Device Name: User1289
Plot Style: Hp1055  50%Di
Plot Style: Hp1055  Ai
Plot Style: Hp1055  Bi
Plot Style: Hp1055  Di
Plot Style: Hp1055 (34in X 96in)
Device Name: User257
Plot Style: Hp1055 (Pipe Template)
Plot Style: Hp1055 34in X 96in
Plot Style: Hp5100 50%Di
Device Name: 11x17
Plot Style: Hp5100 Ai
Device Name: Letter
Plot Style: Hp5100 Bi
Device Name: 11x17
Plot Style: Hp5200 (50%Di)
Device Name: 11x17
Plot Style: Hp5200 (Ai)
Device Name: Letter
Plot Style: Hp5200 (Bi)
Device Name: 11x17
Plot Style: Hp5200 50%Di
Device Name: 11x17
Plot Style: Hp5200 Ai
Device Name: Letter
Plot Style: Hp5200 Bi
Device Name: 11x17
Plot Style: Hp5dn  50%Di  North
Device Name: 11x17
Plot Style: Hp5dn  Ai  North
Device Name: Letter
Plot Style: Hp5dn  Bi  North
Device Name: 11x17
Plot Style: LXM-W812  50%Di  South
Device Name: Tabloid
Plot Style: LXM-W812  Ai  South
Device Name: Letter
Plot Style: LXM-W812  Bi  South
Plot Style: LXM-W812 (50%Di) South
Plot Style: LXM-W812 (Ai) South
Device Name: Letter
Plot Style: LXM-W812 (Bi) South
Plot Style: Oce (34in X 96in)
Device Name: UserDefinedImperial (34.00 x 96.00Inches)
Plot Style: Oce (50%Di)
Device Name: ANSI_expand_B__(17.00_x_11.00_Inches)
Plot Style: Oce (Ai)
Device Name: ANSI_expand_A_(11.00_x_8.50_Inches)
Plot Style: Oce (Bi)
Plot Style: Oce (Di)
Device Name: ANSI_expand_D_(34.00_x_22.00_Inches)
Plot Style: Oce 34in X 96in
Plot Style: Oce 50%Di
Plot Style: Oce Ai
Plot Style: Oce Bi
Plot Style: Oce Di
mjrenaud
« Reply #8 on: September 28, 2013, 12:12:34 PM »
Thanks for this piece of code. It works very well, when you're in that dwg. I guess I wasn't very clear at the beginning... when I said that I was trying to read a Template file, I meant that I was trying to read a Template file from within another dwg. Sorry for the confusion on this.
WILL HATCH
« Reply #9 on: September 28, 2013, 02:57:00 PM »
Strange, I'm having no issues doing what you're after.  Does this work on your machine?
Code - C#: [Select]
  3.         {
  6.             using (Database db = new Database(false, false))
  7.             {
  8.                 db.ReadDwgFile(@"C:\Layouts Imperial.dwt", FileShare.Read, false, null);
  9.                 using (Transaction tr = db.TransactionManager.StartTransaction())
  10.                 {
  11.                     DBDictionary Settings = (DBDictionary)tr.GetObject(db.PlotSettingsDictionaryId, OpenMode.ForRead);
  12.                     foreach (DBDictionaryEntry PlotSetting in Settings)
  13.                     {
  14.                         try
  15.                         {
  16.                             ed.WriteMessage("\nPlot Style: {0}", PlotSetting.Key);
  17.                             PlotSettings ps = (PlotSettings)tr.GetObject(PlotSetting.Value, OpenMode.ForRead);
  18.                             ed.WriteMessage("\nDevice Name: {0}", ps.CanonicalMediaName);
  19.                         }
  20.                         catch (System.Exception e)
  21.                         {
  22.                             ed.WriteMessage("\n{0}", e.ToString());
  23.                         }
  24.                     }
  25.                 }
  26.             }
  27.         }
mjrenaud
« Reply #10 on: September 28, 2013, 03:23:05 PM »
Well, that did it! The only significant different was that I was using GetSourceDatabase() instead of ReadDwgFile().
Thanks very much for your help.
WILL HATCH
« Reply #11 on: September 28, 2013, 07:07:14 PM »
There is no GetSourceDatabase function within the autocad API... are you referring to the method posted in this thread?
WILL HATCH
« Reply #12 on: September 28, 2013, 07:45:54 PM »
Just because I can see some good use for this type of function I've done some playing, I'd love for somebody to critic this:
Code - C#: [Select]
  3.         {
  7.             using (Transaction tr = db.TransactionManager.StartTransaction())
  8.             using (Database ndb = NewDatabase(@"C:\Layouts Imperial.dwt"))
  9.             {
  10.                 DBDictionary plotSettings = (DBDictionary)tr.GetObject(db.PlotSettingsDictionaryId, OpenMode.ForWrite);
  11.                 DBDictionary newPlotSettings = (DBDictionary)tr.GetObject(ndb.PlotSettingsDictionaryId, OpenMode.ForRead);
  12.                 foreach (DBDictionaryEntry newPlotSetting in newPlotSettings)
  13.                 {
  14.                     try
  15.                     {
  16.                         PlotSettings nps = (PlotSettings)tr.GetObject(newPlotSetting.Value, OpenMode.ForRead);
  17.                         PlotSettings ps;
  18.                         if (!plotSettings.Contains(newPlotSetting.Key))
  19.                         {
  20.                             ed.WriteMessage("\nImporting Plot Style: {0}", newPlotSetting.Key);
  21.                             ps = new PlotSettings(nps.ModelType);
  22.                             db.AddDBObject(ps);
  23.                             tr.AddNewlyCreatedDBObject(ps, true);
  24.                             plotSettings.SetAt(newPlotSetting.Key, ps);
  25.                         }
  26.                         else
  27.                         {
  28.                             ed.WriteMessage("\nUpdating Plot Style: {0}", newPlotSetting.Key);
  29.                             ps = (PlotSettings)tr.GetObject(plotSettings.GetAt(newPlotSetting.Key), OpenMode.ForWrite);
  30.                         }
  31.                         ps.CopyFrom(nps);
  32.                     }
  33.                     catch (System.Exception e)
  34.                     {
  35.                         ed.WriteMessage("\n{0}", e.ToString());
  36.                     }
  37.                 }
  38.                 tr.Commit();
  39.             }
  40.         }
  41.         private Database NewDatabase(string path)
  42.         {
  43.             Database db = new Database(false, false);
  44.             db.ReadDwgFile(path, FileShare.Read, false, null);
  45.             return db;
  46.         }
Chumplybum
« Reply #13 on: September 29, 2013, 06:41:21 PM »
Hi Will,
One thing I would add is db.CloseInput() after the db.readdwgfile in your NewDatabase function... see note 2, http://adndevblog.typepad.com/autocad/2012/07/using-readdwgfile-with-net-attachxref-or-objectarx-acdbattachxref.html
cheers, Mark
WILL HATCH
« Reply #14 on: September 30, 2013, 01:58:14 PM »
I initially had, and usually do when I'm going to modify the side loaded database, but in this case where I was only grabbing a couple things out of the database it was much faster to do a lazy load by not asserting CloseInput. I had read that Fenton post long ago and my interpretation was that it's only important when you plan to modify the database. Do you know if this is actually setting up for any issues?
