Author Topic: Burst Command - Error or just funky?  (Read 1657 times)
Big G
« on: March 20, 2013, 08:44:21 PM »
Binding xrefs, bursting blocks across multiple layouts seems to include the blocks from all the layouts.
Basically i do a burst all to nuke the dynamic blocks and titleblock info from the drawings prior to archiving. I noticed this morning when doing it, that the blocks from the other 4 or 5 layouts appear on all the layouts after bursting.
I have recreated this a few times with the same results.
Just a heads-up in case someone is using the burst all function in a script or lsp file.
a) Image 1 - blocks on a typ layout
b) Copy layout (to end)
c) move blocks to new location
d) burst, all to select all the blocks
e) Image 2, with both the blocks shown in the layout.
G
[edit: sorry wrong section on forum can someone slide to cad general]
« Last Edit: March 20, 2013, 09:08:32 PM by Big G »
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
Re: Burst Command - Error or just funky?
« Reply #1 on: March 20, 2013, 10:06:17 PM »
Yep.
