Author Topic: Search text after string  (Read 2744 times)
cadplayer
  • Autocad Civil3d, OpenDCL.Runtime, LISP, .NET (C#)
« on: March 13, 2013, 09:46:53 AM »
Hi!
I´m looking for a tool which can search Textstrings and calculate them how much it find in drawing.
I try to begin that, but I´m really down and can´t continue, can somebody help me ?
; Lösche duplicates in Liste
(defun _RemoveDuplicates ( lst / foo index )
    (defun foo (x)
            ((vl-position x index))
            ((null (setq index (cons x index))))
    (vl-remove-if
       'foo
        lst
(defun c:searchText (/ txt ss i ent layEnt layList layTXT txtwert txtliste )
  (if (not x) (setq x ""))
  (if (null (setq txt (getstring (strcat "\nSearch [text] <" x ">: "))))
    (setq txt x)
    (setq x txt)
  (if (setq ss (ssget "_X" '((8 . "H_N_VA*") (0 . "TEXT") (-4 . "<NOT") (-4 . "*") (420 . 0) (-4 . "NOT>"))) i 0)
    (repeat (sslength ss)
      (setq ent (ssname ss i))
(setq layEnt (cons ent (cdr (assoc 1 (entget ent)))))
(setq layList (cons layEnt layList))
  (setq tl (strlen txt))
 (if (setq layTXT (_RemoveDuplicates (mapcar 'cdr layList)) txtwert 0)
   (foreach N layList
     (if (= (cdr N) (car layTXT))
(setq txtwert (cdr (assoc 1 (entget (car N)))))
(setq txtliste (cons txtwert txtliste))
Re: Search text after string
« Reply #1 on: March 13, 2013, 10:10:25 AM »
Maybe:
  1. (defun c:tfind ( / sel )
  2.     (if
  3.         (setq sel
  4.             (ssget "_X"
  5.                 (list '(0 . "TEXT")
  6.                     (cons 1
  7.                         (apply 'strcat
  8.                             (mapcar '(lambda ( x ) (strcat "[" (chr x) (strcase (chr x) t) "]"))
  9.                                 (vl-string->list (strcase (getstring t "\nEnter Text: ")))
  10.                             )
  11.                         )
  12.                     )
  13.                 )
  14.             )
  15.         )
  16.         (print (sslength sel))
  17.         (princ "\nText not found.")
  18.     )
  19.     (princ)
  20. )
cadplayer
« Reply #2 on: March 13, 2013, 10:30:21 AM »
Really complex - I have to study.
Thanks so much Lee
« Reply #3 on: March 13, 2013, 10:40:40 AM »
You're welcome; if you aren't worried about case-sensitivity, the code could be shortened to:
  2.     (if (setq sel (ssget "_X" (list '(0 . "TEXT") (cons 1 (getstring t "\nEnter Text: ")))))
  3.         (print (sslength sel))
  4.         (princ "\nText not found.")
  5.     )
  6.     (princ)
  7. )
cadplayer
« Reply #4 on: March 13, 2013, 11:31:55 AM »
Thanks Lee for fast answering, I´m little busy right now, but I come back if I understand more what you have done.
Thanks a lot :)
cadplayer
« Reply #5 on: March 15, 2013, 03:57:40 AM »
A question more, if I want have all text with prefix TB- , VA-, TELE I was thinking it would goes like this, but I doesn´t.
(defun c:test ()
  (if (setq ss (ssget "_X" '((8 . "H_N*") (0 . "TEXT") (-4 . "<NOT") (-4 . "*") (420 . 0) (-4 . "NOT>"))) i -1)
      (setq ent (ssname ss (setq i (1+ i))))
      (if (tfind (setq y (substr (cdr (assoc 1 (entget ent))) 1 3)))
(princ (strcat "\nValue " y  " is [" (rtos z 2 0) "] in Drawing " ))
 (defun tfind (y / sel )
           (setq sel
               (ssget "X"
                   (list '(0 . "TEXT")
                       (cons 1
                           (apply 'strcat
                                   (vl-string->list (strcase y))
           (princ (setq z (sslength sel)))
« Reply #6 on: March 15, 2013, 07:24:46 AM »
I suggest something like this:
(defun c:test ( / inc itm lst sel str )
    (if (setq sel (ssget "_X" '((0 . "TEXT") (1 . "TB-*,VA-*,TELE*"))))
        (repeat (setq inc (sslength sel))
            (setq str (cdr (assoc 1 (entget (ssname sel (setq inc (1- inc)))))))
            (if (setq itm (assoc str lst))
                (setq lst (subst (cons str (1+ (cdr itm))) itm lst))
                (setq lst (cons  (cons str 1) lst))
    (mapcar 'print lst)
cadplayer
« Reply #7 on: March 15, 2013, 08:44:05 AM »
Wonderfull Lee!
I must slowly go through the code, I didn´t really understand what happens in the end. But give me little time, after weekend I understand it ...
« Reply #8 on: March 15, 2013, 08:46:07 AM »
You're welcome Dirk, ask if you are unsure about the code.  :-)
cadplayer
« Reply #9 on: April 19, 2013, 07:34:27 AM »
Its a little complicate to understand this part of your code
(apply 'strcat
what did it do ?
How can I debugg x with vlide?
« Reply #10 on: April 19, 2013, 08:26:10 AM »
Maybe this will explain it:
  1. (apply 'strcat   ; this combines the strings returned by the mapcar
  2.
  3.     (mapcar '(lambda ( x ) ; the following returns a string
  4.                (strcat ; combine string
  5.                   "["  ; this character
  6.                   (chr x) ; convert number to ascii character
  7.                   (strcase (chr x) t) ; convert number to ascii character & force to lower case
  8.                   "]"  ; this character
  9.                 ) ; end strcat
  10.               ) ; end lanbda
  11.
  12.         ; the following is the list of ascii numbers fed to the lambda function
  13.         (vl-string->list (strcase y)) ; convert string y to upper case & return a list of ascii numbers
  14.     ) ; end mapcar
  15.
  16. ) ; end apply
« Reply #11 on: April 19, 2013, 08:26:59 AM »
(apply 'strcat
What did it do?
Evaluating the code expression-by-expression:
_$ (setq y "test")
"test"
_$ (strcase y)
"TEST"
_$ (vl-string->list (strcase y))
(84 69 83 84)
_$ (mapcar '(lambda ( x ) (strcat "[" (chr x) (strcase (chr x) t) "]")) (vl-string->list (strcase y)))
("[Tt]" "[Ee]" "[Ss]" "[Tt]")
_$ (apply 'strcat (mapcar '(lambda ( x ) (strcat "[" (chr x) (strcase (chr x) t) "]")) (vl-string->list (strcase y))))
"[Tt][Ee][Ss][Tt]"
Since the DXF Group 1 code of the ssget filter list is case-sensitive, the above expressions construct a wildcard pattern that will match both the uppercase and lowercase variants of each character of the given string.
cadplayer
« Reply #12 on: April 19, 2013, 10:07:36 AM »
Thanks so much Lee
Have a nice we!
