Author Topic: ACAD 2013 Open Drawing  (Read 9552 times)
stevenh0616
« on: December 12, 2012, 03:59:20 PM »
Anyone know how to open a drawing programmatically in ACAD 2013? The developer doc (link below) says to do the following, but when I do the acDocMgr.Open says it does not belong to DocumentCollection. I'm thinking this is something they moved with the new API changes. Thoughts???
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-330A8DCB-626F-4271-8B89-9773A7631D87.htm,topicNumber=d30e716937
Code - vb.net: [Select]
  1. Imports System.IO
  2. Imports Autodesk.AutoCAD.ApplicationServices
  3. Imports Autodesk.AutoCAD.DatabaseServices
  4. Imports Autodesk.AutoCAD.Runtime
  5.
  6. <CommandMethod("OpenDrawing", CommandFlags.Session)> _
  7. Public Sub OpenDrawing()
  8.   Dim strFileName As String = "C:\campus.dwg"
  9.   Dim acDocMgr As DocumentCollection = Application.DocumentManager
  10.
  11.   If (File.Exists(strFileName)) Then
  12.       acDocMgr.Open(strFileName, False)
  13.   Else
  14.       acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strFileName & _
  15.                                                      " does not exist.")
  16.   End If
  17. End Sub
  18.
BlackBox
Re: ACAD 2013 Open Drawing
« Reply #1 on: December 12, 2012, 04:28:26 PM »
Did you add the necessary reference to AcCoreMgd.dll?
<snip>
Extension methods exposed by one type, look like methods of another type.
The Open() method was a member of the DocumentCollection class in previous releases. In AutoCAD 2013, Open() is a member of another class, but is an extension method that target's the DocumentCollection class, which means the method can be called as if it was still a member of DocumentCollection, and calls to it that worked in AutoCAD 2012 will continue to work in AutoCAD 2013, provided the assembly containing the extension method is referenced.
<snip>
« Reply #2 on: December 12, 2012, 04:39:29 PM »
You might want to see the 2013 Migration video Stephen Preston made, specifically at about the 3:10 mark.
Download and extract the zip, then load the html file in your browser.
http://adndevblog.typepad.com/autocad/2012/04/migrating-objectarx-and-net-plug-ins-to-autocad-2013.html
stevenh0616
« Reply #3 on: December 12, 2012, 05:33:49 PM »
Thanks to you both.
I did know to add the acCoreMgd.dll, but have not seen the DocumentCollectionExtension. I'll make sure I watch the video thouroughly!!  8-)
stevenh0616
« Reply #4 on: December 12, 2012, 06:27:50 PM »
Actually I'm still getting an error. It builds fine within Visual Studio and loads into CAD fine. When I try to run a command to open a drawing I get the error "Invalid Execution Context."
The error still occurs on "acDocMgr.Open(Path, False)"
I've followed all the 2013 conversion properties... not sure why it's not working. Here's my code.
  3. Imports Autodesk.AutoCAD.ApplicationServices.DocumentCollectionExtension
  4. Imports Autodesk.AutoCAD.DatabaseServices
  5. Imports Autodesk.AutoCAD.Runtime
  6.
  7. Public Class OpenDrawing
  8.     Public Shared Sub Open(ByVal Path As String)
  10.
  11.         If (File.Exists(Path)) Then
  12.             acDocMgr.Open(Path, False)
  13.         Else
  14.             acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & Path & " does not exist.")
  15.         End If
  16.     End Sub
  17. End Class
Thanks for the help.
tonofsteel
« Reply #5 on: December 12, 2012, 06:41:03 PM »
Are you trying to open a drawing in AutoCAD from an external program?  The .NET libraries are meant to be used from in-process in AutoCAD and after you create a .dll it needs to be netloaded to run.
If you are trying to open a drawing from out of process then you need to use COM.
stevenh0616
« Reply #6 on: December 12, 2012, 06:42:45 PM »
Thanks.
No, this is being run from inside of CAD, so what I'm doing should work just fine - as documented in the AutoCAD Developers Guide.
« Reply #7 on: December 12, 2012, 07:02:51 PM »
You need to be in the Application context.
You are in the document context.
You can use commandFlag.Session or I think there might be a method that will switch it for you.
« Reply #8 on: December 12, 2012, 07:07:27 PM »
Thanks.
From developers guide
Code - Visual Basic: [Select]
  1.
  2.  <CommandMethod("NewDrawing", CommandFlags.Session)> _
  3. Public Sub NewDrawing()
  4.   '' Specify the template to use, if the template is not found
  5.  '' the default settings are used.
  6.  Dim strTemplatePath As String = "acad.dwt"
  7.
  8.   Dim acDocMgr As DocumentCollection = Application.DocumentManager
  9.   Dim acDoc As Document = acDocMgr.Add(strTemplatePath)
  10.   acDocMgr.MdiActiveDocument = acDoc
  11. End Sub
  12.
  13.
Notice the  <CommandMethod("NewDrawing", CommandFlags.Session)> _
Glad they did not name it RunInApplicationContext because that would be confusing.
BlackBox
« Reply #9 on: December 12, 2012, 08:38:51 PM »
<snip>
 :lmao:
TheMaster
« Reply #10 on: December 12, 2012, 08:49:32 PM »
It should be plainly obvious that the OP's code is a .NET extension.
stevenh0616
« Reply #11 on: December 13, 2012, 12:01:42 AM »
Thanks again everyone.
My overall goal was to allow the user to select a drawing a make some edits to XREFs in the selected drawings database, without opening the file. IE: Unload/reload XREFs prior to opening the file (This I have working well).
My next step, within the same command was to take the original selected file and open it. So initially I was thinking of using this open sub from the .NET developers guide, not having much experience with Command Flags. I did read up on these more and have a better understanding.
For what I'm looking to do, it seems using SendStringtoExecute is a better option I think. Unless somebody as a better idea...
BEEB.NET
« Reply #12 on: January 26, 2013, 05:31:40 AM »
        Dim This As Document = DocumentCollectionExtension.Open(acDocMgr, "D:\test.dwg", True)
