Author Topic: I need a lisp that changes the first character of attributes  (Read 7554 times)
antistar
I have many blocks of attributes with values as: F521, G622, D773...
I need a lisp that changes the first character of these attributes to the same value: A521, A622, A773...
Does anyone have a routine that does this?
Thanks in advance.
« Last Edit: July 03, 2012, 09:28:50 AM by antistar »
Re: I need a lisp that changes the first character of attributes
« Reply #1 on: July 03, 2012, 09:07:44 AM »
Use the substr function to remove the first character, then the strcat function to add an 'A' to the front.
i.e.
  1. (strcat "A" (substr <attribute value> 2))
Tharwat
  • Hypersensitive
« Reply #2 on: July 03, 2012, 09:13:09 AM »
This .... ?
  1. (defun c:Test (/ s)
  2.   (if (setq s (ssget "_:L" '((0 . "ATTDEF"))))
  3.     ((lambda (i / n)
  4.        (while (setq n (ssname s (setq i (1+ i))))
  5.          (entmod
  6.            (subst
  7.              (cons 2
  8.                    (strcat "A"
  9.                            (substr (cdr (assoc 2 (entget n)))
  10.                                    2
  11.                                    (strlen (cdr (assoc 2 (entget n))))
  12.                            )
  13.                    )
  14.              )
  15.              (assoc 2 (entget n))
  16.              (entget n)
  17.            )
  18.          )
  19.        )
  20.      )
  21.       -1
  22.     )
  23.     (princ)
  24.   )
  25.   (princ)
  26. )
  27.
  28.
antistar
« Reply #3 on: July 03, 2012, 09:27:59 AM »
This .... ?
  3.     ((lambda (i / n)
  5.          (entmod
  6.            (subst
  7.              (cons 2
  8.                    (strcat "A"
  10.                                    2
  12.                            )
  13.                    )
  14.              )
  16.              (entget n)
  17.            )
  18.          )
  19.        )
  20.      )
  21.       -1
  22.     )
  23.     (princ)
  24.   )
  25.   (princ)
  26. )
  27.
  28.
Tharwat, thanks for your reply.
I need to select the blocks.
It would be like this?
...(setq s (ssget "_: L" '((0. "INSERT") (66. 1))))
« Reply #4 on: July 03, 2012, 09:30:40 AM »
  • Select the blocks (ssget with filter list)
  • Iterate over the Selection Set (repeat / while, ssname)
  • For each block entity in the set, iterate over the attributes (entnext)
  • Retrieve the attribute values (cdr, assoc DXF group code 1)
  • Modify the value (as demonstrated above, substr, strcat)
  • Update the value (subst, entmod, entupd)
« Last Edit: July 03, 2012, 11:54:16 AM by Lee Mac »
dong95
« Reply #5 on: July 03, 2012, 11:01:15 AM »
Very clear instruction, Lee.
I learned a lot. Thanks.
« Reply #6 on: July 03, 2012, 11:30:23 AM »
Is there more than one attribute in the inserts?
If so how will that attribute be identified?
« Reply #7 on: July 03, 2012, 11:54:47 AM »
I'm glad my post was beneficial to your learning dong95  :-)
Tharwat
  • Hypersensitive
« Reply #8 on: July 03, 2012, 12:48:49 PM »
  1. (defun c:Test (/ selectionset integer selectionsetname v)
  2.   ;;; Tharwat 03. July. 2012 ;;;
  3.   (if (not acdoc)
  4.   )
  5.   (if (setq selectionset (ssget "_:L" '((0 . "INSERT") (66 . 1))))
  6.     (progn
  7.       (vla-StartUndoMark acdoc)
  8.       (repeat (setq integer (sslength selectionset))
  9.         (setq selectionsetname  (ssname selectionset (setq integer (1- integer)) ) )
  10.         (foreach x (vlax-invoke
  11.                      (vlax-ename->vla-object selectionsetname)  'GetAttributes )
  12.                           (vla-put-textstring x
  13.                                    (strcat "A" (substr (setq v (vla-get-textstring x)) 2 (strlen v)) )) )
  14.                   )
  15.       (vla-EndUndoMark acdoc)
  16.     )
  17.     (princ)
  18.   )
  19.   (princ)
  20. )
« Last Edit: July 03, 2012, 01:09:20 PM by Tharwat »
antistar
« Reply #9 on: July 03, 2012, 01:06:33 PM »
  3.   (cond (not acdoc)
  4.   )
  6.     (progn
  14.                   )
  16.     )
  17.     (princ)
  18.   )
  19.   (princ)
  20. )
Tharwat, is not working.
Show this error:
ERROR: bad argument type: VLA-OBJECT nil
antistar
« Reply #11 on: July 03, 2012, 01:32:36 PM »
Lee,
Thank you for your explanations.  :-)
antistar
« Reply #12 on: July 03, 2012, 01:35:56 PM »
UPDATED :
Perfect, exactly what I need. It will be very useful to me.
Thank you for your attention and patience.
Regards.
Tharwat
  • Hypersensitive
« Reply #13 on: July 03, 2012, 01:37:29 PM »
UPDATED :
Regards.
You're welcome anytime .  :wink:
« Reply #14 on: July 03, 2012, 01:41:32 PM »
Lee,
Evidently wasting my time since the code has been provided on a plate.
