Author Topic: Q: inserting images  (Read 3170 times)
Fuccaro
Q: inserting images
« on: February 25, 2005, 01:23:37 PM »
How can I insert an image using AutoLisp? The IMAGEATTACH function doesn't have a command line version. Calling like
(COMMAND "IMAGEATTACH") will cause the dialog box to pop up. But I try to send all the parameters (insertion point, scale) to AutoCAD from the Lisp.
Also I was unable to do it by manipulating the DXF codes. Can somebody help please?
Q: inserting images
« Reply #1 on: February 25, 2005, 01:54:11 PM »
Try setting filedia to 0 then use -image.
Enter new value for FILEDIA <1>: 0
Command: -image
Enter image option [?/Detach/Path/Reload/Unload/Attach] <Attach>:
Enter image file name to attach: *Cancel*
Fuccaro
Q: inserting images
« Reply #2 on: February 28, 2005, 05:23:52 AM »
It works, Thank you Ronjonp! :)
