Author Topic: Moving Point now changes elevation?  (Read 11176 times)
Re: Moving Point now changes elevation?
« Reply #15 on: May 24, 2012, 01:35:54 PM »
I just posted a question about this, Mark. During my testing I encountered the same fatal error you mention above. I sent in the CER and within minutes I had an email from Tech support asking about it. I sent back the exact steps I had just gone through, and mentioned WHY I was doing the test (the change in workflow between 2012 & 2103 point grip editing). So I know it's in their system now.
Thank ya sir. :)
« Reply #16 on: May 25, 2012, 09:35:48 AM »
Well, it appears that 2012 is the only version which holds the point's elevation when grip editing. Matt Kolberg tested versions 2009-2013 and reported these findings. I then tested in 2010 and 2011 myself and also found this to be the case. Sinc and Steve Boon also chimed in with similar findings.
It would be nice if there was a setting that we could use to enable/disable this, as I can see where it would be handy for either method to be used.
« Reply #17 on: June 05, 2012, 10:56:09 AM »
Any 'news' on this? I'm working on a huge (for me) DTM and it's driving me up the friggin wall.
BlackBox
« Reply #18 on: June 05, 2012, 11:17:59 AM »
Jeff, would it be possible (in the mean time, waiting for Autodesk to formally fix this), to use an Event monitor for when a Point3d is Grip Edited, to store the Z prior to Grip Edit, and replace Z after Grip Edit?
It should also be simple enough to add a registry key, and CommandMethod to allow the user to toggle this setting, no?
... Still very new to C#, but conceptually this seems possible (to me).  :-D Perhaps you can clarify.
« Reply #19 on: June 05, 2012, 12:28:58 PM »
Renderman, I think this could be done with GripOverrules. But I'm not well versed in them and I don't have much time to play today. Kean and Stephen Preston have posted examples in the past. I'll see if I can check this idea out this evening.
BlackBox
« Reply #20 on: June 05, 2012, 12:32:42 PM »
I've never heard of GripOverrules... Sounds great, thanks for looking into this!
« Reply #21 on: June 05, 2012, 12:49:50 PM »
Thank you Jeff.
« Reply #22 on: June 05, 2012, 10:52:40 PM »
Thank you Jeff.
Happy to try, Mark. However, upon deeper investigation, the grips aren't exposed in the API for the Points. I got what I thought would work (and does work on basic Acad objects) but once the point is selected, all grips disappear so you cannot move it at all with grips. So now I'm off to see what can be done using Renderman's suggestion, but without access to the grips I'm not sure how to limit it to when a point is grip edited. More research is needed...not sure how much time I can spend until the weekend, but I'll try to come up with something.
BlackBox
« Reply #23 on: June 05, 2012, 11:28:18 PM »
Thank you Jeff.
It is unfortunate that yet more Aecc* features are lacking from those already exposed to the .NET API, but I am glad that I at least was able to offer an alternative (albeit unorthodox) method.
FWIW - This may be thinking too much like a LISP-er, but I use a Visual LISP Command Reactor to monitor when a user grip edits objects (using the GRIP_STRETCH Command) to automagically toggle the user's CursorSize from 5% to 100%, perhaps you can translate the obscure LISP dialect into a more refined C# snippet of code?  :lol: LoL
« Reply #24 on: June 06, 2012, 07:47:25 AM »
My intent was not for you to come up with a solution Jeff. I would really like to hear from Autodesk. :)
« Reply #25 on: June 06, 2012, 09:24:37 AM »
Uh, huh. I have no doubt that what you will hear is that 2012 was broken and it was fixed in 2013, therefor nothing will be done about it. Hence my quest for a solution. Have you logged a support request through the Subscription site?
You can workaround this, although it is a bit slower workflow. When picking the location to move to, use the .XY filter and pick the location, it will ask for the Z, now move back to the original grip and the CogoPoint will then use it's original elevation (provided the styles used for display are set to "Use Point Elevation").
« Reply #26 on: June 06, 2012, 09:50:05 AM »
No, I have not. Not sure I can even get to that site from here. LOL
BINGO!! Thanks Jeff. Never thought about using point filters. That will work!
