Author Topic: How to check if coordinates are equal ?  (Read 9897 times)
Coder
« on: May 09, 2012, 02:03:16 PM »
Hello .
I would like to check if a coordinate is a member in a list .
  (setq mylist (23.337 6.63198) (22.9351 6.23005) (22.9351 8.02967) (16.5646 12.593) (14.5698 8.22248) (9.64711 7.83685) (6.42968 11.661) (6.42968 5.65161))
this code fail >>>>
(mapcar (function (lambda (coord)
  (if (member '(23.337 6.63198) coord)
    (setq num (1+ num))
    mylist
and this one also >>>>
  (if (vl-position '(23.337 6.63198) coord)
    (setq num (1+ num))
    mylist
dgorsman
Re: How to check if coordinates are equal ?
« Reply #1 on: May 09, 2012, 02:29:45 PM »
Coordinates may have additional numbers past the displayed precision, so unlike definite information (e.g. "a" always matches "a") its very difficult to get an exact match out of a list with (member...), (vl-position...), etc. which by default do an (= ...) type check which requires an exact match.
Consider rolling your own comparison function using (equal...) so you can specify a fuzz-factor.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
gile
  • Marseille, France
« Reply #2 on: May 09, 2012, 02:32:02 PM »
(defun gc:memberFuzz (expr lst fuzz)
  (while (and lst (not (equal (car lst) expr fuzz)))
    (setq lst (cdr lst))
  lst
« Reply #3 on: May 09, 2012, 02:39:20 PM »
+1 on the roll yer own and "equal"
In your lambda function, try comparing the X and Y coords independently using a fuzz factor
(and (equal 23.337 (car coord) 0.0001)(equal 6.63198 (cadr coord) 0.0001))
« Reply #4 on: May 09, 2012, 03:25:22 PM »
  1. (defun MemberWithFuzz ( itm lst fuzz )
  2.     (vl-member-if '(lambda ( x ) (equal x itm fuzz)) lst)
  3. )
Coder
« Reply #5 on: May 09, 2012, 03:34:06 PM »
Thank you all guys . :-)
What is the best value for fuzz ?
« Reply #6 on: May 09, 2012, 03:37:32 PM »
peach
Coder
« Reply #7 on: May 09, 2012, 03:57:41 PM »
fixo
« Reply #8 on: May 09, 2012, 04:13:04 PM »
0.00001 would be enough for your list
dgorsman
« Reply #9 on: May 09, 2012, 04:28:14 PM »
I generally aim for one decimal place smaller than the most precise number e.g. coordinates are in millimeters, I would use a fuzz factor of 0.1 (mm).  If coordinates are in meters to three decimal places i.e. m.mmm I would use 0.0001 (m).
try {GreatPower;}
   finally
      {MasterBasics;}
« Reply #10 on: May 09, 2012, 10:15:55 PM »
Bill's beard.
sorry, you probably had to be there :)
Coder
« Reply #11 on: May 10, 2012, 02:00:39 AM »
Bill's beard.
Hi Kerry .
I have no idea about that , can you please be more straight to the point . ?  :wink:
Thank you
Coder
« Reply #12 on: May 13, 2012, 08:22:45 AM »
I am sorry guys , I am still don't know how to chose the correct value for the fuzz and how to filter a list of coordinates to
remove the equal one from the list.  :oops:
Stefan
« Reply #13 on: May 13, 2012, 08:47:49 AM »
Remove a point from a list:
  1. (defun remove_point (point lst)
  2.   (if (equal point (car lst) 1e-4)
  3.     (cdr lst)
  4.     (if lst (cons (car lst) (remove_point point (cdr lst))))
  5.     )
  6.   )
  7.
_$ (setq mylist '((23.337 6.63198) (22.9351 6.23005) (22.9351 8.02967) (16.5646 12.593) (14.5698 8.22248) (9.64711 7.83685) (6.42968 11.661) (6.42968 5.65161)))
_$ (remove_point '(16.5646 12.593) mylist)
((23.337 6.63198) (22.9351 6.23005) (22.9351 8.02967) (14.5698 8.22248) (9.64711 7.83685) (6.42968 11.661) (6.42968 5.65161))
A precision of 1e-4 would be enough.
Stefan
« Reply #14 on: May 13, 2012, 09:00:38 AM »
Previous lisp will remove only first instance of a point from a list of points.
To remove all points, use this
  2.   (if lst
  3.     (if (equal point (car lst) 1e-4)
  4.       (remove_point point (cdr lst))
  5.       (cons (car lst) (remove_point point (cdr lst)))
  6.       )
  7.     )
  8.   )
