Author Topic: plot file - save as dialog - in current directory  (Read 2541 times)
lamarn
« on: February 17, 2012, 05:00:05 AM »
I have a routine that sets all the initial directories to the directory that the drwaing is opened.
Somehow i cannot make it work for the plot file directory.
I want to make default that the plot file save screen comes up with the current directory in which the DWG is opened.
Could use some help, anyone that has a workaround or code to get this done?
Hans
(defun updatepaths ()
(if (not *rjp-commandreactors*)
  (setq *rjp-commandreactors* (vlr-command-reactor nil '((:vlr-commandwillstart . strtcmd))))
(defun strtcmd (calling-reactor strtcmdinfo / dp hkcu key regpath)
  (if (and (= (getvar 'dwgtitled) 1)
           (wcmatch (car strtcmdinfo) "*XREF,XATTACH,*SHEET*,ETRANSMIT,OPEN")
    (progn (setq dp   (getvar 'dwgprefix)
                 hkcu (strcat "HKEY_CURRENT_USER\\" (vlax-product-key))
                 key  (strcat hkcu "\\Profiles\\" (getvar 'cprofile) "\\Dialogs\\") ; PLOT FILE DIRECTORY ?!!!!!!!!!!!!!!!!!!!!
           (setq regpath (strcat key "XattachFileDialog"))
           (vl-registry-write regpath "InitialDirectory" dp)
           (setq regpath (strcat key "XrefFileDialog"))
           (setq regpath (strcat key "Sheet Set Wizard")) ;sheet sets
           (vl-registry-write regpath "BrowseForLayoutsPath" dp)
           (vl-registry-write regpath "SheetSetCreatePath" dp) ; etransmit
           (setq regpath (strcat key "eTransAddFile"))
           (setq regpath (strcat key "SSMNavigator"))
           (vl-registry-write regpath "OpenSheetSetPath" dp)
           (vl-registry-write regpath "ImportLayoutsAsSheetsPath" dp) ; import layouts
           (setq regpath (strcat key "OpenSaveAnavDialogs"))
           (vl-registry-write regpath "InitialDirectory" dp) ;open/save dir
           (setq regpath (strcat key "AcDxSaveDxDialog"))
           (vl-registry-write regpath "InitialDirectory" dp) ;DXE data extraction
           (setq regpath (strcat key "AcSmNav:OpenSheetSet"))
           (vl-registry-write regpath "InitialDirectory" dp) ;Sheetset
           (setq regpath (strcat key "BrowseforDrawingFileBlkDlg"))
           (vl-registry-write regpath "InitialDirectory" dp) ;blocks to write
           (setq regpath (strcat key "BrowseforPlotFilePlotDlg"))
           (vl-registry-write regpath "InitialDirectory" dp) ;pdf plot (?!)
   (vl-registry-write regpath "(Default)" dp)   ;pdf plot (?!)
           (vl-registry-write regpath "FileNameMRU0" dp) ;pdf plot (?!)
           (setq regpath (strcat key "BrowseropenDialog"))
           (vl-registry-write regpath "InitialDirectory" dp) ;?
           (setq regpath (strcat key "DWFNavDlg"))
           (setq regpath (strcat key "DWGopenDialog"))
           (setq regpath (strcat key "Export Data"))
           (setq regpath (strcat key "IMAGEopenDialog"))
           (setq regpath (strcat key "Import File"))
           (setq regpath (strcat key "LayerStatesFileDialog"))
           (setq regpath (strcat key "OUTPUTFOLDERDLG"))
           (setq regpath (strcat key "ProfileExportFileDialog"))
      (setq regpath (strcat key "AcLaytransFindFile"))
      (setq regpath (strcat key "WhoHas"))
      (setq regpath (strcat key "Specify Zip File"))
      (setq regpath (strcat key "Select template"))
      (setq regpath (strcat key "Select Script File"))
      (setq regpath (strcat key "Select Page Setup From File"))
      (setq regpath (strcat key "Select a file"))
      (setq regpath (strcat key "Save Drawing As"))
      (setq regpath (strcat key "PSETUPNavDlg"))
      (setq regpath (strcat key "ProfileImportFileDialog"))
      (setq regpath (strcat key "Create Mass and Area Properties File"))
(vla-put-defaultplottofilepath
  (vla-get-output (vla-get-preferences (vlax-get-acad-object)))
  (getvar 'dwgprefix)
Design is something you should do with both hands. My 2d hand , my 3d hand ..
Re: plot file - save as dialog - in current directory
« Reply #1 on: February 17, 2012, 09:35:38 AM »
You might need to add (wcmatch (car strtcmdinfo) "*XREF,XATTACH,*SHEET*,ETRANSMIT,OPEN,PLOT") to the reactor list. I'll see if I can find the key you're looking for.
This should do it:  :-)
  (getvar 'dwgprefix)
 :oops: Looks like that is already included in the snippet above. Guess I should have read a bit more :-P.
Could probably shorten this code up a bit using
and some conditionals.
« Last Edit: February 17, 2012, 09:46:34 AM by ronjonp »
