Author Topic: Double-Click Behavior  (Read 3568 times)
BlackBox
Re: Double-Click Behavior
« Reply #15 on: December 06, 2011, 11:42:05 AM »
I would think the controlling factor would be whether the pgp file was read before or after the cui file.  I am not sure which is first.
It appears that the PGP file is loaded after the CUI - from another thread:
<Snip>
Consider the load order at startup:
linky
A. CUI files loaded:
1. Enterprise
2. Main
3. Partials to Main
4. Partials to Enterprise
B. acad*.* files loaded:
1. Files listed in acad.rx
2. acad2009.lsp
3. acad.lsp  <--
4. acad2009doc.lsp
5. acaddoc.lsp
6. acad.dvb
C. CUI-associated MNL and LSP files loaded:
1. Enterprise named MNL
2. Enterprise loaded LSP and MNL
3. Main named MNL
4. Main loaded LSP and MNL
5. Partials to Main named MNLs
6. Partials to Main loaded LSPs and MNLs
7. Partials to Enterprise named MNLs
8. Partials to Enterprise loaded LSPs and MNLs
D. Startup suite files loaded
E. Startup routines run:
1. AcadStartup() called (AutoCAD startup)
2. AcadDocument_Activate() called (Drawing startup)
3. (S::STARTUP) called
4. SCR loaded from /b switch
Edit: ^^ Corrected
« Reply #16 on: December 06, 2011, 01:21:56 PM »
you will probably discover use of the normal command name presents fewer unexpected results than use of an alias.
Irrespective of what or who gets loaded first, I'm sticking with my original answer.
Matt__W
  • I like my water diluted.
« Reply #17 on: December 06, 2011, 01:24:00 PM »
I believe the word you meant to use was "irregardless".   :lol:
Autodesk Expert Elite
BlueMoon
« Reply #18 on: December 06, 2011, 02:12:14 PM »
I know it is accepted in everyday language but the word "irregardless" is actually a double negative.  There is a belief that it was a blend of "irrespective" and "regardless".  $0.02
BM
Matt__W
« Reply #19 on: December 06, 2011, 02:31:12 PM »
BM
Irregardless of what you say.... That's why I used the LOL smiley.   :lol:
BlackBox
« Reply #20 on: December 06, 2011, 02:32:57 PM »
BM
I see what you did there. :lol:
BlueMoon
« Reply #21 on: December 06, 2011, 03:44:07 PM »
 :lol: :lol:
BM
