Author Topic: Lisp to open a note pad  (Read 14151 times)
CadFrank
« on: November 17, 2011, 01:28:15 PM »
Hi, I would like to know if a lisp routine exist for the fallowing explanation.
Ok well i have a Notepad saved as TimeTracker.txt in my desktop.
Would it be possible that when i press CTRL+S in AutoCad drawing that the file .txt open.
I would also like to know how i keep a .lsp loaded in a .dwt file.
Thx alot for all the help.
Cheers & Beers
Re: Lisp to open a note pad
« Reply #1 on: November 17, 2011, 01:34:09 PM »
(startapp "notepad" "C:\\YourFilename.txt")
CadFrank
« Reply #2 on: November 17, 2011, 01:39:20 PM »
Ok, lets say I do not know how to creat a lisp routine.
where would i put the script you posted?
« Reply #3 on: November 17, 2011, 01:45:30 PM »
At the point in your program at which you want the Text file to open, for example:
(defun c:test ( )
    (getstring "\nPress Enter to open Notepad...")
    (startapp "notepad")
Or, as a better example:
(defun c:test ( / file )
    (if (setq file (getfiled "Select Text File to Open" "" "txt" 16))
        (startapp "notepad" file)
CadFrank
« Reply #4 on: November 17, 2011, 01:45:59 PM »
Would this work?
(defun c:timet()
(startapp "notepad" "C:\\TimeTracker.txt")
CadFrank
« Reply #5 on: November 17, 2011, 01:46:56 PM »
So this would make it start when i press Ctrl+s or Save
« Reply #6 on: November 17, 2011, 01:48:34 PM »
No, for that you would need to alter your cui.
CadFrank
« Reply #7 on: November 17, 2011, 01:50:37 PM »
Would altering my cui. be hard or creat problems?
« Reply #8 on: November 17, 2011, 01:57:50 PM »
Not too difficult...
Type CUI at the command-line, navigate to 'Keyboard Shortcuts' > 'Shortcut Keys' > 'Save'
Alter the macro to call the LISP function before (or after) executing the 'qsave' command, e.g.:
^C^C(c:test);_.qsave
CadFrank
« Reply #9 on: November 17, 2011, 02:11:02 PM »
Ok it works when i Save.. But if the text file i only want to open is TimeTracker.txt and i want it to open when i press Ctrl+S what should i change in the routine.
(defun c:timet ( / file )
    (if (setq file (getfiled "Select Text file To Open" "" "txt" 16))
alanjt
  • Standby for witty remark...
« Reply #10 on: November 17, 2011, 02:12:28 PM »
You can also do this from the commandline by default (defined in acad.pgp). just type NOTEPAD
Dropbox
« Reply #11 on: November 17, 2011, 02:14:42 PM »
Hint:
That's a new one for me, thanks.  :-)
CadFrank
« Reply #12 on: November 17, 2011, 02:21:42 PM »
So it writes impossible to open file
        (startapp "notepad" "C:\\Timetracker.txt")
Where should i put my .txt file for it to be found?
« Reply #13 on: November 17, 2011, 02:42:07 PM »
Anywhere - as long as the filepath in the startapp expression matches the location of the text file.
(startapp "notepad" <filepath of textfile>)
CadFrank
« Reply #14 on: November 17, 2011, 02:42:14 PM »
well i found the problem i guess i took out one of the 2 "\" int the C:\\TimeTracker.txt and it worked :D
Well Thx alot for your help Lee
Cheers & Beers !
