Author Topic: Edit Column Width/Height for MText - has anyone figured this out?  (Read 4514 times)
alanjt
  • Standby for witty remark...
I generally use zero width text, so I hadn't noticed, but today I tried to change the width of some MText with my width editing routine and it didn't work. Has anyone come up with a way to edit the column width/height on MText (testing in v2011) in code?
vla-put-width no long works on MText. :(
Here's my width editing code:
(defun c:WD (/ ss wd)
  ;; Change width of selected MText and MultiLeader objects
  ;; Alan J. Thompson, 11.05.09
  (if (and (setq ss (ssget "_:L" '((0 . "MTEXT,MULTILEADER"))))
           (setq wd (initget 4)
                 wd (cond ((getdist "\nWidth <0.0>: "))
                          (0.)
      (vlax-for x (setq ss (vla-get-activeselectionset
                             (cond (*AcadDoc*)
                                   ((setq *AcadDoc* (vla-get-activedocument
                                                      (vlax-get-acad-object)
        (vl-catch-all-apply
          (function vlax-put-property)
          (list x
                (cond ((eq (vla-get-objectname x) "AcDbMText") 'Width)
                      ((eq (vla-get-objectname x) "AcDbMLeader") 'TextWidth)
                wd
      (vla-delete ss)
Dropbox
mkweaver
Re: Edit Column Width/Height for MText - has anyone figured this out?
« Reply #1 on: November 17, 2011, 12:11:15 PM »
That is curious.
In 2012, even entmod doesn't work.  It appears to work - the returned list has the modified 41 value, but nothing changes on the entity:
(setq
  ent (car (entsel))
  elist (entget ent)
  test (entmod (subst (cons 41 (getdist)) (assoc 41 elist) elist))
(princ (assoc 41 elist))
(princ (assoc 41 test))
(princ (assoc 41 (entget ent)))
((-1 . <Entity name: 7ffff60f660>) (0 . "MTEXT") (330 . <Entity name: 7ffff6039f0>) (5 . "509EE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "20-LITE") (100 . "AcDbMText") (10 31.9157 -4.75434 0.0) (40 . 0.09375) (41 . 2.56575) (46 . 0.0) (71 . 1) (72 . 5) (1 . "This is a test") (7 . "Standard") (210 0.0 0.0 1.0) (11 1.0 0.0 0.0) (42 . 0.629464) (43 . 0.25) (50 . 0.0) (73 . 1) (44 . 1.0))
(41 . 0.821385)(41 . 0.821385)
(41 . 2.56575)(41 . 2.56575)
So entmod accepts the change, the value changes, but there is no visible change in the object.  Even the properties palette still shows the old value.  I wonder if the width value is stored in xdata or a dictionary...
alanjt
« Reply #2 on: November 17, 2011, 12:13:45 PM »
Damn.
Yeah,
(vla-put-width (vlax-ename->vla-object (car (entsel))) 0.) doesn't throw an error, it just doesn't do anything.
Dropbox
« Reply #3 on: November 17, 2011, 12:14:38 PM »
Does an entupd or vla-update remedy?
« Reply #4 on: November 17, 2011, 12:15:40 PM »
MTEXTCOLUMN = 0
With Dynamic Columns set, the MText width becomes read-only; set this to No Columns.
alanjt
« Reply #5 on: November 17, 2011, 12:22:50 PM »
no dice.
MTEXTCOLUMN = 0
Well I'll be damned. <adds setting change to acaddoc.lsp>
Of course, this doesn't help existing MText.
Dropbox
eddybeerke
  • Mosquito
« Reply #6 on: March 08, 2018, 06:44:18 AM »
Is there a solution found?
In order to make a good use of the boundingbox (for blocks with mtext(s) in  it) i need to change the Columns to None and the Defined width to 0.
« Reply #7 on: March 08, 2018, 08:33:22 AM »
You can determine the bounding box surrounding MText content (not the MText frame) using DXF groups 42 & 43, you don't need to modify the MText width.
