Author Topic: Read Registry  (Read 3404 times)
Harrie
Read Registry
« on: July 23, 2011, 04:12:10 PM »
What is wrong in:
(vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\Sound")and in
(setq shell (vlax-create-object "Wscript.Shell")
key   "Hkey-current-user\\Control Panel\\sound"
val   (vlax-invoke shell "regread" key)
Re: Read Registry
« Reply #1 on: July 23, 2011, 04:52:55 PM »
maybe this:
_$ (vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\Sound" "Beep")
"yes"
_$
HofCAD
Re: Read Registry
« Reply #2 on: July 24, 2011, 09:55:08 AM »
What is wrong in:
Maybe this(notice the underscore [ _ ] or understrike):
key   "HKEY_CURRENT_USER\\Control Panel\\Sound\\Beep"
val   (vlax-invoke shell 'regread key)
or
key   "HKEY_CURRENT_USER\\Control Panel\\Sound\\ExtendedSounds"
Regards HofCAD CSI.
« Last Edit: July 24, 2011, 10:03:00 AM by HofCAD »
chlh_jd
Re: Read Registry
« Reply #3 on: July 30, 2011, 02:25:57 AM »
anthoer e.g.
  ;; Get CLSID from ProgID
  (defun GetClassID (ProgID)
    (vl-registry-read
      (strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")
register activex services
;; Register hello ActiveX services,
;; if not already registered.
(defun Register (classid filename / server)
  ;; Register ActiveX server (dll/ocx)
  ;; This requires RegSvr32.exe to be on the DOS path
  (defun RegServer (server)
    (startapp
      "regsvr32.exe"
      (strcat "/s \"" server "\"")
    (vl-registry-read
    ((GetClassID classid))
    ((not (setq server (findfile filename)))
     (alert (strcat " Error: Can't find file ("
    filename
    "),please put it in the 'support' folder!"
    (t
     (regserver server)
     (or
       (alert "Error: Can't register ActiveX Services, Please contact the author !")
« Last Edit: July 30, 2011, 02:32:12 AM by chlh_jd »
Re: Read Registry
« Reply #4 on: July 30, 2011, 10:31:54 AM »
Didn't Tony Tanzillo write that?
chlh_jd
Re: Read Registry
« Reply #5 on: August 03, 2011, 03:11:16 AM »
Hi LeeMac ,  it come from the web,  at that time there's no author's info . I'll found the author .
Can you sure it's writen by Tony Tanzillo ?
Re: Read Registry
« Reply #6 on: August 03, 2011, 07:18:58 AM »
I think I remember seeing something like it on his site a while back, but his site is no longer available...   :|
