Author Topic: Generic Dictionary  (Read 14983 times)
cadpro
Generic Dictionary
« on: July 21, 2011, 10:56:30 AM »
Is it possible to add a Generic .NET Dictionary to an XRecord, or convert a .NET Dictionary to DBDictionary?
dgorsman
Re: Generic Dictionary
« Reply #1 on: July 21, 2011, 11:52:08 AM »
Can't do the first (but you *can* add a soft or hard pointer to another Extension Dictionary in the XRecord), but the second could be done with a bit of work, depending on whats in the Dictionary object.  You could map each entry in the Dictionary into a separate Extension Dictionary with the contents stored in a single XRecord, or you could use a single Extension Dictionary with multiple XRecords, or even a single Extension Dictionary with a single XRecord with multiple DXF content.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
cadpro
« Reply #2 on: July 21, 2011, 12:04:14 PM »
Thanks for the reply.
The Generic Dictionary contains a Key of string datatype and the Value is a String Array. Could you give me some example code on how to map this to the Xrecord.
kaefer
« Reply #3 on: July 21, 2011, 12:15:01 PM »
Those suggestions are very cool, there's only a bit of background necessary to explain why:
AutoCAD's internal data structures traditionally predate .NET generics, so they implement the non-generic variety of IDictionary and IEnumerable for DBDictionary. That means they're either stuck with boxed objects -- cf. IDictionary.Add(object key, object value) --, or they declare which concrete data types to use, which are string and ObjectId here. Since you can do reverse look-up with the NameAt method, either Dictionary<string,ObjectId> or Dictionary<ObjectId,string> could be mapped in a one-on-one fashion to a DBDictionary.
cadpro
« Reply #4 on: July 21, 2011, 12:44:39 PM »
Please can I get some sample code?
kaefer
« Reply #5 on: July 21, 2011, 12:51:03 PM »
    let db = HostApplicationServices.WorkingDatabase
    use tr = db.TransactionManager.StartTransaction()
    let key = "xyz"
    let strings = [| "foo"; "bar"; "fred" |]
    let lt = tr.GetObject(db.LayerTableId, OpenMode.ForWrite) :?> LayerTable
    if lt.ExtensionDictionary.IsNull then
        lt.CreateExtensionDictionary()
    let ext = tr.GetObject(lt.ExtensionDictionary, OpenMode.ForWrite) :?> DBDictionary
    let tvs =
        strings |> Array.map (fun s ->
            new TypedValue(int DxfCode.ExtendedDataAsciiString, s) )
    let rb = new ResultBuffer(tvs)
    let xr = new Xrecord(Data = rb)
    ext.SetAt(key, xr)|> ignore
    tr.AddNewlyCreatedDBObject(xr, true)
    tr.Commit()
Makes a Xrecord from a ResultBuffer created from an array of TypedValue pairs corresponding to a string array and adds it with the key "xyz" to the ExtensionDictionary of LayerTable.  You didn't specify the language...
« Reply #6 on: July 21, 2011, 01:12:14 PM »
Do you guys think it would be too much of a performance hit to pass a object type to a method's parameter and use Reflection to take care of the adding the codetype?
Nice kaefer and dgorsman
cadpro
« Reply #7 on: July 21, 2011, 01:32:32 PM »
Sorry, I'm working on VB.NET. Also, I wish to link the Dictionary to the whole drawing, rather than any Table in the drawing, so that this dictionary can be read from the drawing.
BTW, the dictionary contains Key as String and Value as List of String Array, that is, List(Of String()). So would it be possible to add to the DBDictionary?
« Last Edit: July 21, 2011, 01:43:47 PM by cadpro »
« Reply #8 on: July 21, 2011, 02:26:44 PM »
Is the key for searching,
and List(of String()) is different than a array-------For you C# List(of String()) == List<string>   Generic list
cadpro
« Reply #9 on: July 21, 2011, 03:16:19 PM »
Sorry, I did not understand your question. Well, I have an already populated Dictionary. I can loop through the Dictionary's KeyValuePair to get the data in it. But don't know how to add it to a DBDictionary.
gile
  • Marseille, France
« Reply #10 on: July 21, 2011, 04:47:25 PM »
Hi
Here's a C# snippet (maybe easier to translate to VB).
A DBDictionary named "StringArraysDictionary" is added (or overwriten) to the named object dictionary and filled with the entries of the Dictionary<string, List<string>> where each entry is considered as a Xrecord.
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace DctionayDBDictionary
    public class Commands
        [CommandMethod("Test")]
        public void Test()
            Dictionary<string, List<string>> dict = new Dictionary<string, List<string>>();
            dict.Add("foo", new List<string> { "a", "b", "c" });
            dict.Add("bar", new List<string> { "x", "y", "z" });
            dict.Add("baz", new List<string> { "this", "is", "a", "test" });
            DictionaryToDBDictionary(dict, "StringArraysDictionary");
        private void DictionaryToDBDictionary(Dictionary<string, List<string>> dict, string dictName)
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
                DBDictionary nod =
                    (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary dbDict;
                try
                    dbDict = tr.GetObject(nod.GetAt(dictName), OpenMode.ForWrite) as DBDictionary;
                    foreach (DBDictionaryEntry entry in dbDict)
                        dbDict.Remove(entry.Key);
                catch
                    nod.UpgradeOpen();
                    dbDict = new DBDictionary();
                    nod.SetAt(dictName, dbDict);
                    tr.AddNewlyCreatedDBObject(dbDict, true);
                foreach (KeyValuePair<string, List<string>> entry in dict)
                    Xrecord xrec = new Xrecord();
                    ResultBuffer datas = new ResultBuffer();
                    foreach (string s in entry.Value)
                        datas.Add(new TypedValue(1, s));
                    xrec.Data = datas;
                    dbDict.SetAt(entry.Key, xrec);
                    tr.AddNewlyCreatedDBObject(xrec, true);
                tr.Commit();
cadpro
« Reply #11 on: July 21, 2011, 08:00:57 PM »
Thanks very much for the code. That was a startup!
I did write it in VB and it works like a charm. But I want to retrieve this dictionary back too. For that, I did some code but not working.
Public Sub Test()
Dim dict as New Dictionary(of String, List(Of String()))
Dim a As String() = New String() {"a", "b"}
Dim b As String() = New String() {"c", "d"}
Dim c As String() = New String() {"e", "f"}
Dim d As String() = New String() {"g", "h"}
Dim e As String() = New String() {"i", "j"}
Dim f As String() = New String() {"k", "l"}
Dim r1 As New List(Of String())
Dim r2 As New List(Of String())
Dim r3 As New List(Of String())
r1.Add(a)
r1.Add(b)
r2.Add(c)
r2.Add(d)
r3.Add(e)
r3.Add(f)
dict.Add("xxx", r1)
dict.Add("yyy", r2)
dict.Add("zzz", r3)
Public Sub GetXrecord()
        Dim doc As Document = acadApp.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim tr As Transaction = db.TransactionManager.StartTransaction
Dim nod as DBDictionary =Nothing
dim nodid as ObjectId =db.NamedObjectsDictionaryId
Using tr as Transaction = db.TransactionManager.StartTransaction
nod = CType(tr.GetObject(nodid, OpenMode.ForRead), DBDictionary)
If Not nod Is Nothing Then
If nod.Contains("StringArraysDictionary") Then
Dim dbDict as DBDictionary = Nothing
Dim idDict as ObjectId = nod.GetAt("StringArraysDictionary")
For Each e in dbDict
Dim xrec as XRecord = CType(tr.GetObject(dbDict.GetAt(e.Key), OpenMode.ForRead), Xrecord)
For Each x In xrec.Data
Dim s as String() = x.Value
Next
Next
End If
End If
End Using
gile
  • Marseille, France
« Reply #12 on: July 22, 2011, 02:28:38 AM »
        [CommandMethod("testback")]
        public void TestBack()
            Editor ed = doc.Editor;
            Dictionary<string, List<string>> dict = DBDictionaryToDictionary("StringArraysDictionary");
            if (dict == null)
                ed.WriteMessage("\nThe 'StringArraysDictionary' dictionary can'tbe found.");
                return;
            foreach (KeyValuePair<string, List<string>> pair in dict)
                string datas = string.Empty;
                foreach (string s in pair.Value)
                    datas += " " + s;
                ed.WriteMessage("\n{0} ={1}", pair.Key, datas);
        private Dictionary<string, List<string>> DBDictionaryToDictionary(string dictName)
                DBDictionary nod =
                try
                    DBDictionary dbDict =
                        (DBDictionary)tr.GetObject(nod.GetAt(dictName), OpenMode.ForRead);
                    Dictionary<string, List<string>> result = new Dictionary<string,List<string>>();
                        Xrecord xrec = tr.GetObject(entry.Value, OpenMode.ForRead) as Xrecord;
                        if (xrec == null)  continue;
                        List<string> strs = new List<string>();
                        ResultBuffer datas = xrec.Data;
                        if (datas == null) continue;
                        foreach (TypedValue tv in datas)
                            if (tv.TypeCode == 1)
                                strs.Add((string)tv.Value);
                        result.Add(entry.Key, strs);
                    return result;
                catch
                    return null;
cadpro
« Reply #13 on: July 22, 2011, 04:02:01 AM »
Hi gile,
My problem lies in adding and retrieving the String Array. My Dictionary contains String as Key and List of String Array as Value. That is
MyDict(Of String, List(Of String())
Hence even though adding the value does not give any error, I could step through to see that the value it takes is System.String[]
Same with retrieving also.
cadpro
« Reply #14 on: July 22, 2011, 06:54:57 AM »
The sample code posted is for List of String. But I'm looking for some code with List of String Array. I cannot get it to work. Any help please!!
