Author Topic: tcase mleader for title case  (Read 7312 times)
butzers09silverado
« on: July 19, 2011, 01:50:36 PM »
So I had this code partially fixed... but it won't change the case to a "title case", it only changes it to upper or lower.  I'd REALLY like to have tcase work on mleaders so you can pick... here's what i've got:
(defun c:demo  (/ ent mleader sset)
  (setvar "errno" 0)
  (while (and (not sset)
       (/= (getvar "errno") 52)
    (prompt "\n   >>   Select multileader >> ")
    (setq sset (ssget "+.:S:N" '((0 . "MULTILEADER"))))
  (if (and sset
    (setq mleader (vlax-ename->vla-object (setq ent (ssname sset 0)))
    (eq acmtextContent (vla-get-contenttype mleader)))
    (vla-put-textstring
      mleader
      (strcase (vla-get-textstring mleader)))); or (strcase T (vla-get-textstring mleader))
gracias
Re: tcase mleader for title case
« Reply #1 on: July 19, 2011, 02:23:08 PM »
butzers09silverado
« Reply #2 on: July 19, 2011, 02:45:48 PM »
I posted in that topic, we could close this one then i guess?  thank you, want to verify it works with multi-leaders.
« Reply #3 on: July 19, 2011, 02:47:24 PM »
Another example:
(defun c:demo ( / *error* ss obj )
  (defun *error* ( msg )
    (setvar 'NOMUTT 0)
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  (setvar 'ERRNO 0)
  (setvar 'NOMUTT 1)
  (princ "\nSelect Multileader: ")
  (while
    (not
      (or
        (setq ss (ssget "_+.:S:E:L" '((0 . "MULTILEADER"))))
        (= 52 (getvar 'ERRNO))
    (and ss
      (eq acmtextcontent
        (vla-get-contenttype (setq obj (vlax-ename->vla-object (ssname ss 0))))
    (vla-put-textstring obj (LM:TitleCase (vla-get-textstring obj)))
  (setvar 'NOMUTT 0)
(defun LM:TitleCase ( s / n )
  (vl-list->string
    (mapcar
      (function
        (lambda ( x )
          (setq n (if (and (or (not n) (= 32 n)) (< 96 x 123)) (boole 2 x 32) x))
      (vl-string->list (strcase s t))
It uses the titlecase function I posted here, (ignore all the other crap that is unfortunately included with that thread).
alanjt
  • Standby for witty remark...
« Reply #4 on: July 19, 2011, 02:49:38 PM »
Damn, that's pretty conceded.
Dropbox
« Reply #5 on: July 19, 2011, 02:52:08 PM »
conceded?
conceded past participle, past tense of con·cede (Verb)
1. Admit that something is true or valid after first denying or resisting it.
alanjt
« Reply #6 on: July 19, 2011, 02:53:59 PM »
conceded?
oops: *conceited*
Dropbox
« Reply #7 on: July 19, 2011, 02:56:50 PM »
oops: *conceited*
I wasn't referring to the code that was posted.  :wink:
alanjt
« Reply #8 on: July 19, 2011, 02:58:06 PM »
oops: *conceited*
suuuure  :wink:
Dropbox
butzers09silverado
« Reply #9 on: July 20, 2011, 08:02:23 AM »
haters gonna hate... lol   :lmao:
We'll give-it-a-go today, I'll let ya know thanks again this could be huge.
butzers09silverado
« Reply #10 on: July 20, 2011, 08:16:08 AM »
tested
it works, AWESOME
just wondering what it would take to get the options in a command line to pick what case we want or some quick direction on how to modify that so i have separate lisp files for:
title
sentence
upper
lower
thoughts?  thanks
alanjt
« Reply #11 on: July 20, 2011, 09:09:43 AM »
Copyright won't allow me to post, but with little effort I was able to hack a mod into the Express Tool: TCASE to work with MLeaders.
Dropbox
« Reply #12 on: July 20, 2011, 09:35:52 AM »
This was fun to write:
(defun c:tcase2 ( / acsel func name ) ;; © Lee Mac 2011
    (ssget "_:L"
        (-4 . "<OR")
          (0 . "ARCALIGNEDTEXT,ATTDEF,*TEXT")
          (-4 . "<AND")
            (0 . "INSERT")
            (66 . 1)
          (-4 . "AND>")
          (-4 . "<AND")
            (0 . "*DIMENSION")
            (1 . "*?*")
          (-4 . "AND>")
          (-4 . "<AND")
            (0 . "MULTILEADER")
            (304 . "~LEADER_LINE{")
          (-4 . "AND>")
        (-4 . "OR>")
      (initget "Sentence Lower Upper Title toGgle")
      (setq func
        (eval
          (cdr
            (assoc
              (setq case
                    (getkword
                      (strcat "\nSpecify Case [Sentence/Lower/Upper/Title/toGgle] <"
                        (setq case (cond ( case ) ( "Upper" ))) ">: "
                  ( case )
                ("Upper" . strcase)
                ("Lower" . (lambda ( x ) (strcase x t)))
                ("Title" . EE:TitleCase)
                ("Sentence" . LM:SentenceCase)
                ("toGgle" . LM:ToggleCase)
      (vlax-for obj
        (setq acsel
          (vla-get-activeselectionset
          ( (wcmatch (setq name (vla-get-objectname obj)) "AcDb*Dimension")
            (vla-put-textoverride obj (func (vla-get-textoverride obj)))
          ( (or (eq "RText" name)(eq "AcDbArcAlignedText" name))
            (vlax-put-property obj 'contents (func (vlax-get-property obj 'contents)))
          ( (eq "AcDbMLeader" name)
            (if (eq acmtextcontent (vla-get-contenttype obj))
              (vla-put-textstring obj (func (vla-get-textstring obj)))
          ( (eq "AcDbBlockReference" name)
            (foreach att (vlax-invoke obj 'getattributes)
              (vla-put-textstring att (func (vla-get-textstring att)))
          ( t
      (vla-delete acsel)
(defun EE:TitleCase ( s ) ;; ElpanovEvgeniy
  (vl-list->string
    (mapcar
      (function
        (lambda ( a b c ) (if (= 32 a) b c))
      (cons 32 (vl-string->list s))
      (vl-string->list (strcase s))
(defun LM:SentenceCase ( s / f )
  (vl-list->string
    (mapcar
      (function
        (lambda ( a b c )
          (if (or f (= 46 a)) (progn (setq f (= 32 b)) b) c)
      (cons 46 (vl-string->list s))
(defun LM:ToggleCase ( s )
  (vl-list->string
    (mapcar
      (function
        (lambda ( a b c ) (if (< 96 a 123) b c))
      (vl-string->list s)
(vl-load-com) (princ)
Note that it won't work with formatted MText however.
« Last Edit: July 20, 2011, 09:40:45 AM by Lee Mac »
butzers09silverado
« Reply #13 on: July 20, 2011, 10:06:53 AM »
by fun do you mean "fun" sarcastically or was it really fun?  lisping is not fun for me because I can't write it... it's fun to try and figure out though..   8-)
alanjt
« Reply #14 on: July 20, 2011, 10:18:39 AM »
At the risk of inflating your ego anymore :wink: very nice work.
TCase doesn't handle all the new formatting very well.
Dropbox
